Asus MAXIMUS VIII EXTREME
ASUS MAXIMUS VIII EXTREME
BIOS MAXIMUS-VIII-EXTREME-ASUS-0907 16MB
Z170 taken to the extreme
  • LGA1151 socket for 6th-gen Intel® Core™ desktop processors.
  • Dual DDR4 3866 (OC) support.
  • Best gaming performance – Intuitive OC Panel II, 5-Way Optimization with Auto-Tuning, Pro Clock, second-generation T-Topology and Extreme Engine Digi+.
  • Best gaming audio – Reinvented SupremeFX 2015 with intuitive Sonic Studio II.
  • Best gaming networking – Best-in-class Intel® Gigabit Ethernet, LANGuard and GameFirst technologies.
  • Best gaming connectivity — Thunderbolt™ 3, 3x3 802.11ac Wi-Fi , NVMe U.2, M.2, SATA Express and USB 3.1 Type-A and Type-C for extreme-speed transfers and total compatibility.
  • Best gaming protection – Carefully-selected premium components for maximum durability.
  • ROG gives you more – More gaming-focused utilities, all free!
  • CPU
    Supports Intel® 14 nm CPU
    * Refer to www.asus.com for CPU support list
  • Chipset
    Intel® Z170
  • Memory
    4 x DIMM, Max. 64GB, DDR4 3866(O.C.)/3800(O.C.)/3733(O.C.)/3600(O.C.)/3500(O.C.)/3466(O.C.)/3400(O.C.)/3333(O.C.)/3300(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666(O.C.)/2400(O.C.)/2133 MHz Non-ECC, Un-buffered Memory
  • Graphic
    Multi-VGA output support : HDMI/DisplayPort 1.2 ports
    - Supports HDMI with max. resolution 4096 x 2160 @ 24 Hz
    - Supports DisplayPort with max. resolution 4096 x 2304 @ 60 Hz
  • Multi-GPU Support
    Supports NVIDIA® Quad-GPU SLI™ Technology
    Supports AMD 4-Way CrossFireX Technology
  • Expansion Slots
    3 x PCIe 3.0/2.0 x16 (x16 or dual x8 or x8/x4/x4, gray)
    1 x PCIe 3.0/2.0 x16 (x4 mode, gray)
    2 x PCIe 3.0/2.0 x1 (black)
  • Storage
    Intel® Z170 chipset :
    1 x M.2 x4 Socket 3, with M Key, type 2242/2260/2280/22110 storage devices support (both SATA & PCIE mode)*1
    6 x SATA 6Gb/s port(s), gray, , 4 ports from 2 x SATA Express
    2 x SATA Express port
    1 x U.2 port
    Support Raid 0, 1, 5, 10
    Intel® Rapid Storage Technology supports*2
    Supports Intel® Smart Response Technology*2
    ASMedia® ASM1061 controller :
    2 x SATA 6Gb/s port(s), black, *3,
  • LAN
    Intel® I219V, 1 x Gigabit LAN Controller(s), GameFirst technology
    Intel® LAN- Dual interconnect between the Integrated LAN controller and Physical Layer (PHY)
    Anti-surge LANGuard
  • Wireless Data Network
    Wi-Fi 802.11 a/b/g/n/ac
    Supports dual band frequency 2.4/5 GHz
    Up to 1300Mbps transfer speed
  • Bluetooth
    Bluetooth V4.0
  • Audio
    ROG SupremeFX 2015 8-Channel High Definition Audio CODEC
    - Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
    - SupremeFX Shielding Technology
    - ESS® ES9023P DAC: dB SNR, dB THD+N (Max. kHz/ -bit)
    - TI RC4580 2VRMS audio OP AMP(s)
    Audio Feature :
    - Gold-plated jacks
    - DTS Connect
    - Sonic SenseAmp
    - Sonic Studio II
    - Sonic Radar II
  • USB Ports
    8 x USB 3.0 port(s) (4 at back panel, blue, 4 at mid-board)
    Intel® Z170 chipset : *4
    6 x USB 2.0 port(s) (6 at mid-board)
    ASMedia® USB 3.1 controller :
    2 x USB 3.1 port(s) (2 at back panel, red, Type-A)
    Intel® USB 3.1 controller :
    2 x USB 3.1 port(s) (2 at back panel, , Type-A + Type-C)
  • ROG Exclusive Features
    Start Button
    Reset Button
    LN2 Mode
    Extreme Engine Digi+ :
    - MicroFine Alloy Chokes
    - 10K Black Metallic Capacitors
    - OptiMOS™ MOSFET
    Mem TweakIt
    ROG Extreme OC kit :
    - ReTry button
    - Safe Boot button
    - Start button
    - Reset button
    - Slow Mode
    - LN2 Mode
    - PCIe x16 Lane Switch
    - Debug LED
    - EZ Plug
    - DRAM channel jumper
    ProbeIt
    KeyBot II
    - One-click Overclocking
    - X.M.P.
    - DirectKey
    - ClrCMOS
    - Power On
    UEFI BIOS features :
    - O.C. Profile
    - GPU.DIMM Post
    - Tweakers' Paradise
    - ROG SSD Secure Erase
    - Graphic Card Information Preview
    ROG RAMDisk
    iROG
    Extreme Tweaker
    USB BIOS Flashback
    Overclocking Protection :
    - COP EX (Component Overheat Protection - EX)
  • OC Panel II
    2.6 " LCM display
    EXTREME/NORMAL mode switch
    EXTREME Mode for subzero OC benching:
    - VGA Hotwire
    - Subzero Sense
    - Slow Mode
    - Pause Switch
    - ProbeIt
    - ReTry button
    - Safe Boot button
    2 x Thermal sensor connectors
    4 x 4-pin extra fan connectors *5
    NORMAL Mode for in-chassis usage:
    - OC button
    - FanSpeed control button
    - LCM backlight on/off button
    I/O Ports:
    - POWER:1 x SATA power connector
    - ROG_EXT port:1 x 18-1 pin data connection port
  • Special Features
    OC Design - ASUS PRO Clock Technology
    - Full BCLK range for extreme overclocking performance
    5-Way Optimization by Dual Intelligent Processors 5
    - 5-Way Optimization tuning key perfectly consolidates TPU, EPU, DIGI+ Power Control, Fan Xpert 3, and Turbo App
    ASUS Wi-Fi GO!
    - Wi-Fi GO! Function: Cloud GO!, Remote Desktop, Remote Keyboard & Mouse, File Transfer
    - Wi-Fi GO! & NFC Remote app for portable smartphone/tablet, supporting iOS 7 & Android 4.0 systems
    ASUS Exclusive Features :
    - GPU Boost
    - MemOK!
    - AI Suite 3
    - Ai Charger+
    - USB 3.1 Boost
    - Disk Unlocker
    - Mobo Connect
    - PC Cleaner
    Remote Entertainment
    - Media Streamer
    - HyStream
    ASUS EZ DIY :
    - ASUS CrashFree BIOS 3
    - ASUS EZ Flash 3
    - ASUS USB BIOS Flashback
    - Push Notice
    ASUS Q-Design :
    - ASUS Q-Shield
    - ASUS Q-Code
    - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    - ASUS Q-Slot
    - ASUS Q-DIMM
    - ASUS Q-Connector
    RAMCache
  • Operating System Support
    Windows® 10 , 64bit
    Windows® 8.1 , 64bit
    Windows® 7 , 32bit/64bit
  • Back I/O Ports
    1 x DisplayPort
    1 x HDMI
    1 x LAN (RJ45) port(s)
    1 x USB 3.1 (black)Type-C
    3 x USB 3.1 (red)Type-A
    4 x USB 3.0 (blue)
    1 x Optical S/PDIF out
    5 x Audio jack(s)
    1 x Clear CMOS button(s)
    1 x USB BIOS Flashback Button(s)
    1 x ASUS Wi-Fi GO! module (Wi-Fi 802.11 a/b/g/n/ac and Bluetooth v4.0/3.0+HS)
  • Internal I/O Ports
    1 x U.2 port
    1 x AAFP connector
    2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s)
    3 x USB 2.0 connector(s) support(s) additional 6 USB 2.0 port(s)
    2 x SATA Express connector: gray, Compatible with 4 x SATA 6.0 Gb/s ports
    1 x M.2 Socket 3 with M Key design, type 2242/2260/2280/22110 storage devices support (Supports both SATA & PCIE SSD)
    4 x SATA 6Gb/s connector(s)
    1 x CPU Fan connector(s) (4 -pin)
    1 x CPU OPT Fan connector(s) (4 -pin)
    4 x Chassis Fan connector(s) (4 -pin)
    1 x Thunderbolt header(s)
    1 x 4-pin ATX 12V Power connector(s)
    1 x 4-pin EZ_PLUG Power connector(s)
    1 x System panel(s) (Q-Connector)
    1 x 5-pin EXT_FAN(Extension Fan) connector
    1 x MemOK! button(s)
    1 x Slow Mode switch(es)
    9 x ProbeIt Measurement Points
    3 x Thermal sensor connector(s)
    1 x DRAM channel jumper
    1 x Power-on button(s)
    1 x Reset button(s)
    1 x BIOS Switch button(s)
    1 x SLI/CFX button (2/3/4-way adjustments)
    1 x Water Pump header (4-pin)
    1 x LN2 Mode jumper(s)
    1 x ROG extension (ROG_EXT) header(s)
    1 x Safe Boot button
    1 x ReTry button
  • Accessories
    User's manual
    ASUS Q-Shield
    8 x SATA 6Gb/s cable(s)
    1 x M.2 Screw Package
    1 x CPU installation tool
    1 x Supporting DVD
    1 x ASUS 3T3R dual band Wi-Fi moving antennas (Wi-Fi 802.11a/b/g/n/ac compliant)
    1 x Fan Extension Card (3 x 4-pin fan out)
    1 x Fan Extension card screw pack
    1 x SLI bridge(s)
    1 x CrossFire cable(s)
    1 x Q-connector(s) (1 in 1)
    3 x Thermal sensor cable pack(s)
    1 x 12 in 1 ROG Cable Label(s)
    ROG Fan Label
    1 x 5-pin to 5-pin cable
    1 x ROG Door Hanger(s)
    OC Panel II :
    1 x OC Panel II(s)
    1 x OC Panel II 5.25-inch bay metal case
    1 x OC Panel II Cable(s)
    1 x OC Panel II screw pack(s)
  • BIOS
    1 x 128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI3.0, WfM2.0, SM BIOS 3.0, ACPI 5.0, Multi-language BIOS, ASUS EZ Flash 3, CrashFree BIOS 3, F11 EZ Tuning Wizard, F6 Qfan Control, F3 My Favorites, F9 Quick Note, Last Modified log, F12 PrintScreen, F3 Shortcut functions and ASUS DRAM SPD (Serial Presence Detect) memory information.
  • Manageability
    WfM2.0, DMI3.0, WOL by PME, PXE
  • Support Disc
    Drivers
    ROG GameFirst technology
    ROG RAMDisk
    ROG RAMCache
    ROG CPU-Z
    ROG Mem TweakIt
    Overwolf
    ROG Keybot II
    Kaspersky® Anti-Virus
    DAEMON Tools Pro Standard
    ASUS WebStorage
    ASUS Utilities
  • Form Factor
    Extended ATX Form Factor
    12 inch x 10.7 inch ( 30.5 cm x 27.2 cm )
  • Note
    *1 The M.2 slot shares bandwidth with U.2 slot and SATA Express 1 slot. Please refers to user manual for detail information.
    *2 This function will work depending on the CPU installed.
    *3 These SATA ports are for data hard drives only. ATAPI devices are not supported.
    *4 2 x USB2.0 port at mid-board comes from the ROG extension (ROG_EXT) port.
    *5 2 of the Fan connectors on OC Panel support PWM mode.
