MACMINI A1347 2010 2.4ghz core 2duo s serial 820-2577A AppleInc.-MM41.88Z.0042.
UnavailableBrd & schematic please
Roman_Tyutin" data-source="post: 156158" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">core 2 non clear meRoman_Tyutin said:clean me please
can u remove password please
820-2577-A
even the original bios doesn't work ?sorry sir that file does not start, don't have another?
The original does boot system from the hard disk but has a password so I want to install system, if I leave ALT pressed to install system the padlock appearseven the original bios doesn't work ?
try file thisThe original does boot system from the hard disk but has a password so I want to install system, if I leave ALT pressed to install system the padlock appears
but with bios here no boot, even if I connect the sensors
same problem sir...try file this
Apple macmini a1347 2010 820-2577A.bin
same problem is bios goodsame problem sir...
