Macbook 12" A1534 - 820-00045-10 820-00045-A
Macbook 12" A1534 BIOS
820-00045-10
820-00045-A
Schematics and Boardview
A1534 820-00045-A.zip
J92 EVT MLB.brd
J92_DVT_mlb_051-00107_820-00045.pdf
J92 Dragon board remind sheet.doc
J92 mlb block diagram v2.pdf
J92 MLB BOTTOM.pdf
J92 MLB TOP.pdf
J92_MLB BOTTOM SIDE.pdf
J92_MLB TOP SIDE.pdf
X261 SMT failure repair_V05.pdf
Hi
If you look on Ebay they selling them and I used one of them unfortunately at this moment I forgot the model # but I did copy and edit and write it back ,works good
thank you, i CH1341A and chipmunk easy flash but always get errors writing..i also have sofi-sp8 but havent figured out how to connect easy flash to sofi-sp8. do you know how? I saw a post that said you use sofi-sp8 to read and write, for me the only way to read/write is to desolder the chip but its a super time killer:fou: (fou)
sorry i not Understand problem for you.
it problem for you, i can help....
Yes please that would be great , I have CH1341A , easy flash adapter and also sofi-sp8
This model reads with ch1341a as micronix but it's windbond? I am able to read but erasing and writing not. Always give error as in screen shot, I used .bin from here and clear Region ME and still same thing[emoji20] 602f190d0d28418b38b882e8b41cd441.jpg5ebfec15822c5f73d9f1ec9665ef743b.jpg
Sent from my SM-G955U using Tapatalk
Hi first you must chose ISP from device like 25q64v (ISP) and hook up chipmunk wire this port
Normally I plug the power supply for the mac in and make sure has the power but computer is off after that I plug in the chipmunk on the socket and try to read after edit and writing on it make sure the chipmunk in the right direction
the connection pictures are very helpfull! thanks a lot. i tried same connection with TL866 programmer but could not detect the chip correctly
