Latitude 5320 1.12.2 19817-1.bin.zip
Wistron SouthPeak13 TGL A00 19817.pdf
send old bios I help buildssouth peak 13 mb 213252-1 bios please upload sir
south peak 13 mb 213252-1 please rebuild my file sir
that builds don't work there are many other problemsnot work this file please ok file build
my file problem 55% after not charging problemthat builds don't work there are many other problems
thử file chứ làm gì có buildslên logo xong tắt kích lại không lên hình
patch 15$It´s locked by ABSOLUTE, i need it to be permanantly disabled.
Payment done, Transaction id 0GL77881B01157236patch 15$
need buy patch 15$Unlock bios !
Go to setup and check to see if computrace is turned offHello
This bios is unlocked and work at first but when i use anything type c connected to the laptop it after couple moments just shutdown or restart, something is wrong with this new bios!
If by computrace you mean absolute then yes! When I went to bios at first it said enabled but I could permanently disable it. So now it's permanently disabled, I needed to enter new service tag too, so I did enter different then the machine was originalyGo to setup and check to see if computrace is turned off
I don't understand what you mean please make a video so I can check the problemIf by computrace you mean absolute then yes! When I went to bios at first it said enabled but I could permanently disable it. So now it's permanently disabled, I needed to enter new service tag too, so I did enter different then the machine was originaly
My bios does not have computrace but it had Absolute! It is disabled!I don't understand what you mean please make a video so I can check the problem
But now laptop is restarting or shutdown once I insert type c device like charger or USB stickMy bios does not have computrace but it had Absolute! It is disabled!
