so need buy patch 35$ fix SSD M2programmed on laptop 1, display ok. but nvme doesn't recognize
and service tag not getting saved. please give me propper solution.
but old file NVMe woking. only I need fan not spinning solutionso need buy patch 35$ fix SSD M2
why you asking $35 for only fan solution?so need buy patch 35$ fix SSD M2
Because SSD m2 is not normalwhy you asking $35 for only fan solution?
dear friend please get my point. old files are supporting SSD, and only problem is fan not spinning.Because SSD m2 is not normal
old bios error what ? Why need builds ??dear friend please get my point. old files are supporting SSD, and only problem is fan not spinning.
i need solution for Fan in my old files. please tell me how ssd issue is comming here?
only fan not spinning.old bios error what ? Why need builds ??
give me solution for fan not workingold bios error what ? Why need builds ??
I think it is in the production mode, does it ask to press ALT+F every time you start?give me solution for fan not working
no not asking for alt+fI think it is in the production mode, does it ask to press ALT+F every time you start?
Try programming that file for the second PC to see the results
make one video problem i checkno not asking for alt+f
tomorrow ok?make one video problem i check
here you see the laptop is absolutely running fine, but fan never spin. problem is only fan not spinning.make one video problem i check
PC 2 same problem ?here you see the laptop is absolutely running fine, but fan never spin. problem is only fan not spinning.
please solve this issue in the bios.
your file fan is spinning but NVMe not detect.
yes same problemPC 2 same problem ?
Try to open a video for the machine to see if the fan is spinning or you need to check the fanyes same problem
Dear friend we watched the machine with running videos and the machine goes to thermal shutdown after about 50 minuets but fan never spin.Try to open a video for the machine to see if the fan is spinning or you need to check the fan
please rebuild this file no video thanksLatitude 3420 213093-1
