Bios Inspiron 16 7610
CYBORG-H TGL-H
203060-1
5J4VT $ CA
CYBORG-H TGL-H
203060-1
5J4VT $ CA
If builds don't work then try adding another biosnot work, once "Dell" splash screen and black screen
another bios not save service tag, not pciM2If builds don't work then try adding another bios
make video problem i checkanother bios not save service tag, not pciM2
fix em file này với ạ có nguồn k lên hình flash 3-6 ạ đã thử flie khác lên nhưng k nhận hộ ssd ạ
3 6 là gì mình cũng ko biết những builds mà vẫn thế thì bios gốc lỗi hoàn toàn rồi ko phục hồi được, nạp file khác rồi mua patch fix SSD thôiflie này vẫn Flash 3 6 ạ
SSD M2 need buy patch 35$Hello Sir.
Please rebuild my Bios. I have no power. With other bios it does start but no SSD. Thanks
I checked the BIOS you provided and it doesn't seem to be the correct model? Inspiron 16 7610 203060-1Ok, I've sent you the payment.
This was the bios on this laptop, maybe someone tried to flash it before and did a good job because the chip seemed intact. Can you patch another bios and not the original? my laptop works with this one but no SSD. My service tag is 9M0HQG3.I checked the BIOS you provided and it doesn't seem to be the correct model? Inspiron 16 7610 203060-1
builds giúp em file gốc anh nhé,dòng nảy đẹp ko lên màn.
builds87.zipNhờ Admin Build giúp! Mất nguồn CPU, nạp file khác không xuất hình.
builds87.zippls builds bios
Bỏ một ly cà phê hôm nay.
