HP Pavilion 14-DV DA0G7GMB8F0 REV:F
BIOS G7G
08987_DMI
BIOS G7G
08987_DMI
That problem I could not help BiosGood morning, the pendrive works but it still doesn't recognize the NVME disk. I've already installed the Intel RST driver and it still isn't recognized.
But what is the reason for not recognizing the disk? Is there anything that can be done? ThanksThat problem I could not help Bios
M2 drive is very annoying it only works with BIOS and original hardwareBut what is the reason for not recognizing the disk? Is there anything that can be done? Thanks
a build giúp e với ạ
Sata you need check hardwareThis BIOS works but it doesn't recognize any of my hard drives.
@ThienBuiNhờ Add Build lại giúp bios này với. Cảm ơn add nhiều!
bulds7.zipNhờ Add Build lại giúp bios này với. Cảm ơn add nhiều!
clsss.zipNhờ anh clear me dùm em, máy không lên hình ạ
bulds7.zipNhờ Admin Build giúp!
bulds7.zipbuild file
bulds7.zipDA0G7GMB8F0 REV.F i5 11th gen no power up and battery not glue read please fix it
test thử file khác nếu vẫn thế thì không phải do biosFix giúp với AD xả pin lên hình đc 1 lần , khởi động lại không lên hình
