HP Main Board Model R62 - DAOR62MB6E1
Rui Fortunato
Active Member
VIP PRO
Hi please I need your help.
This Main Board has one resistor " on fire" (R499) and I can not find the component that is doing this.
Have you this situation before?
I alredi change the resistor, but when the adaptor is connected the resistor was burned like a fuse!!!
Please help
Regards
Please help
Regards
Remove the resistance to separate the circuit. Once removed it measures in diode mode (red terminal in GND and black terminal in both points of the removed R). You tell me the measurement values that it gives you.
Hello Friends,
With new Super I/O and new resistor but the problem is the same. The resistor R499 continue "on fire"
Would you please send the Boardview?
