HP Error Codes
HP COLOR 4600, 5500 ERROR 40 BAD SERIAL TRANSMISSION / BAD EIO CARD
• A serial data error (parity framing, or line over run) has occurred during the reception of data
• A connection with the EIO card in slot X has been abnormally interrupted
• Check that all cables are connection to the EIO ports and that the EIO board is seated properly
HP 8500
• An EIO accessory connection has been abnormally broken while transferring data from the computer to the printer
• Print an EIO configuration page to verify that the EIO accessories are installed properly
• Check that all cables are connected to the EIO ports and that the EIO accessory is seated properly
• Turn the printer off and on to reset it (data will be lost)...
HP 8500
HP Error Codes.pdf
