BIOS HP ENVY 17.3 inch Laptop PC 17-cr0000 IDS Base Model IPA74 LA-M058P
Hi
Do you also have EC firmware dump (ENE KB9542QF2) for this board LA-M058P?
Laptop model: HP ENVY 17-cr0003na.
I believe my EC chip is dead and I need a good dump to reprogram it.
Thanks in advance!
Hi again ThienBui,
Thank you very much for your help and for sharing the file.
I was able to read the dump from my original EC chip (ENE KB9542QF2, board LA-M058P, HP ENVY 17-cr0003na) using SVOD — and my original dump is 128 KB.
The file you posted is 160 KB, so I just wanted to ask — for this model, should the correct EC firmware size be 128 KB or 160 KB?
Just want to make sure I use the right version.
I really appreciate your great work and support!
Hi again ThienBui,
ec this use rom
KB9542QF2
Thank you very much for your reply!
Just to be sure — the EC file you posted is 160 KB, but my board LA-M058P with KB9542QF2 seems to use 128 KB EC ROM.
Could you please confirm — does your 160 KB EC dump really fit this board (LA-M058P / HP ENVY 17-cr0003na), or should I better use my own 128 KB dump?
I just want to avoid any problems when programming a new EC chip.
Many thanks again for your help!
With the new EC chip, it is still possible to measure normal backup, all ICs are available ROM
Hello
I have tested both the EC dump you provided and the BIOS dump above — unfortunately, the laptop still does not power on.
I now suspect that the new EC chip I received from China may be faulty.
Thank you very much again for your help and support!
