you need try more BIOS othersr. power on but problem is bios corrupt.. shutdown and no recovery image again.
i try some bios in the post, and nothing works.. same problem, i dowloaded the bios in the hp but no have a create booteable.. stops.. error ..you need try more BIOS other
Hola
por favor aclarame esta bios dan14nmb6d0 rev d
BIOS builds same problem ?MAESTRO, YA PROGRAMÉ ESA BIOS Y ME SIGUE DANDO EL MISMO ERROR. POR FAVOR, AYÚDAME..
thanks u so much this bios 100 % ok goodi need this model files (DAN14NMBDO REVMODEL: N14N(Trout)
UnavailableEsquema disponible?
plz helpautomatic going in bios update plz help
buildss11.zipautomatic going in bios update plz help
after program bios this error is showing
BIOS old you send same problem ?after program bios this error is showing
before automatically going to bios updateBIOS old you send same problem ?
I check file you send backup error not full dataautomatic going in bios update plz help
can you send me correct bios plzI check file you send backup error not full data
Of course the BIOS I sent above is correct but there are recovery errors you can try adding another BIOS on topcan you send me correct bios plz
