HP HP 830 G5 6050A2930901
even Original bios SSD is not detecting?
Yes original no detection, and BIOS from 1st post also not detecting SSD. CPU broken? (PCIe lanes?) but is detecting WIFI card (WIFI is using PCIe lanes also). I checked Q1951 (mosfet on PEDET line and is OK). I checked filtering capacitors on data lanes and their are fine also.
I can run Windows from USB and laptop apart SSD detection works fine.
I also have no way to check from the BIOS, some new generation M2 usually doesn't work if using other BIOS or clearme
To fix it you need to determine where the problem starts…
pls rebuild this i copy the bios for password and send u for password removal after u send me back i programme bios but no display i check original still no display i don't under stand i use jig to copy bios i check bios data looks ok no damage on board thanks
unpas9033.zip
return old bios and send photo display lock I check
