BIOS HP 250 G7 EPW50 LA-G07FP
HP 250 G7 EPW50 LA-G07FP REV: 1.0
BIOS, Schematics
HP 250 G7 Compal LA-G07FP EPW50 Rev 1.0 (v0.3).pdf
so the original BIOS you sent is completely unrecoverable, if other BIOS programming then M2/nvme won't work, Motherboard have port sata ?
have M2 port but not using. only use HDD port. now i trying to flash with old one that you rebuild, but no display. any solution ?
I also don't know if it is possible that you programmed many times leading to the error of the Motherboard
