ASUS H170 PRO GAMING
BIOS H170-PRO-GAMING-ASUS-0403 16MB
Well-built ATX gaming board loaded with gaming-optimized features
- LGA1151 socket for 6th-gen Intel® Core™ i7 / Core i5 / Core i3, Pentium® and Celeron Processors
- Dual DDR4 2133 support
- SupremeFX: Flawless audio that makes you part of the game
- Sonic Radar ll: Scan and detect your enemies to dominate
- Intel Gigabit Ethernet, LANGuard and GameFirst III: Top-speed protected networking
- RAMCache: Speed up your game loads
- Gamer's Guardian: Highly-durable components and smart DIY features
- USB 3.1 Type-A/C and M.2: Ultra-speedy transfers for faster gaming
- CPU
Supports Intel® 14 nm CPU
- Chipset
Intel® H170 - Memory
4 x DIMM, Max. 64GB, DDR4 2133 MHz Non-ECC, Un-buffered Memory
- Graphic
Multi-VGA output support : HDMI/DVI-D/RGB/DisplayPort ports
- Supports HDMI with max. resolution 4096 x 2160 @ 24 Hz
- Supports DisplayPort with max. resolution 4096 x 2304 @ 60 Hz
Supports Intel® InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™ - Multi-GPU Support
Supports AMD Quad-GPU CrossFireX™ Technology - Expansion Slots
1 x PCIe 3.0/2.0 x16
1 x PCIe 3.0/2.0 x16 (x4 mode, black)
4 x PCIe 3.0/2.0 x1 - Storage
Intel® H170 chipset :
1 x SATA Express port, Compatible with 2 x SATA 6.0 Gb/s ports
1 x M.2 Socket 3, with M Key, type 2242/2260/2280/22110 storage devices support (both SATA & PCIE mode)*1
4 x SATA 6Gb/s port(s)
Support Raid 0, 1, 5, 10
Supports Intel® Smart Response Technology*2 - LAN
Intel® I219V, 1 x Gigabit LAN Controller(s), GameFirst technology
Anti-surge LANGuard - Audio
SupremeFX 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel MIC Jack-retasking
- High quality 115 dB SNR stereo playback output
Audio Feature :
- SupremeFX Shielding™ Technology
- Sonic Radar II - USB Ports
ASMedia® USB 3.1 controller :
1 x USB 3.1 port(s) (1 at back panel, , Type-A)
1 x USB 3.1 port(s) (1 at back panel, , Type-C, Reversible)
6 x USB 3.0/2.0 port(s) (2 at back panel, , 4 at mid-board)
8 x USB 2.0/1.1 port(s) (2 at back panel, , 6 at mid-board) - Special Features
Gamer's Guardian:
- ESD Guards on LAN, Audio, KBMS and USB3.0/2.0 ports
- DRAM Overcurrent Protection
- Stainless Steel Back I/O
- Highly Durable Components
- DIGI+ VRM
ASUS Exclusive Features :
- GPU Boost
- AI Suite 3
- Ai Charger+
- USB 3.1 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- Stylish Fanless Design Heat-sink solution & MOS Heatsink
- ASUS Fan Xpert 3
ASUS EZ DIY :
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 3
- ASUS UEFI BIOS EZ Mode
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
Media Streamer
RAMCache - Operating System Support
Windows® 10 , 64bit
Windows® 8.1 , 64bit
Windows® 7 , 32bit/64bit - Back I/O Ports
1 x DVI-D
1 x D-Sub
1 x DisplayPort
1 x HDMI
1 x LAN (RJ45) port(s)
1 x USB 3.1 (black)Type-C
1 x USB 3.1 (red)Type-A
2 x USB 3.0
2 x USB 2.0
1 x Optical S/PDIF out
5 x Audio jack(s) - Internal I/O Ports
2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s)
3 x USB 2.0 connector(s) support(s) additional 6 USB 2.0 port(s)
1 x SATA Express connector: , Compatible with 2 x SATA 6.0 Gb/s ports
1 x M.2 Socket 3 with M Key design, type 2242/2260/2280/22110 storage devices support (Supports both SATA & PCIE SSD)
1 x COM port(s) connector(s)
4 x SATA 6Gb/s connector(s)
1 x CPU OPT Fan connector(s) (1 x 4 -pin)
3 x Chassis Fan connector(s) (3 x 4 -pin)
1 x System panel(s)
1 x Thermal sensor connector(s)
1 x CPU OV
1 x Clear CMOS jumper(s)
1 x 5-pin EXT_FAN(Extension Fan) connector
1 x ROG extension (ROG_EXT) header(s)
1 x 14-1 pin TPM connector - Accessories
User's manual
I/O Shield
4 x SATA 6Gb/s cable(s)
1 x M.2 Screw Package
1 x Supporting DVD
1 x 12 in 1 Cable Label (s) - BIOS
128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI 3.0, WfM 2.0, SM BIOS 3.0, ACPI 5.0, Multi-language BIOS, ASUS EZ Flash 3,CrashFree BIOS 3, F11 EZ Tuning Wizard, F6 Qfan Control, F3 My Favorites, F9 Quick Note, F12 PrintScreen function and ASUS DRAM SPD (Serial Presence Detect) memory information - Manageability
WfM 2.0, DMI 3.0, WOL by PME, PXE - Support Disc
Drivers
ASUS Utilities
ASUS EZ Update
Anti-virus software (OEM version) - Form Factor
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm ) - Note
*1:When the M.2 Socket 3 is operating in SATA mode, SATA port 1 will be disabled.
*2:These functions will work depending on the CPU installed.
H170-PRO-GAMING-ASUS-0403.BIN.zip
