Asus H170-PLUS D3
ASUS H170-PLUS D3
BIOS H170-PLUS-D3-ASUS-0404 16MB
Full-featured ATX H170 with 5X Protection II for dependable stability, DDR3/DDR3L memory compatibility, and UEFI BIOS with EZ Flash 3
  • 5X Protection II – Advanced hardware safeguards for all-round protection
  • DDR3/DDR3L memory compatibility
  • Lightning-fast M.2 with PCIe® 3.0 x4 interface
  • Epic gaming audio with noise-isolation design
  • Media-acclaimed UEFI BIOS with EZ Flash 3
  • Easy PC DIY with safe motherboard-mounting design
  • Fan Xpert 2+ advanced fan controls for ultimate cooling and silent performance
  • CPU
    Supports Intel® 14 nm CPU
  • Chipset
    Intel® H170
  • Memory
    4 x DIMM, Max. 64GB, DDR3 1866(O.C.)/1600/1333 MHz Non-ECC, Un-buffered Memory
    * The maximum memory frequency supported varies by processor.
  • Graphic
    Multi-VGA output support : HDMI/DVI-D/RGB ports
    Supports up to 3 displays simultaneously
  • Multi-GPU Support
  • Expansion Slots
    1 x PCIe 3.0/2.0 x16 (x16 mode, gray)
    1 x PCIe 3.0/2.0 x16 (max at x4 mode, black)
    2 x PCIe 3.0/2.0 x1
    2 x PCI
  • Storage
    Intel® H170 chipset :
    1 x M.2 Socket 3, , with M key, type 2242/2260/2280 storage devices support (both SATA & PCIE mode)
    4 x SATA 6Gb/s port(s), gray,
    Support Raid 0, 1, 5, 10
    Supports Intel® Smart Response Technology*1
  • LAN
    Realtek® RTL8111H, 1 x Gigabit LAN Controller(s)
  • Audio
    Realtek® ALC887 8-Channel High Definition Audio CODEC *2
    - Supports : Jack-detection, Front Panel Jack-retasking
    Audio Feature :
  • USB Ports
    8 x USB 3.0/2.0 port(s) (4 at back panel, blue, 4 at mid-board)
    6 x USB 2.0/1.1 port(s) (2 at back panel, black, 4 at mid-board)
  • Special Features
    ASUS 5X Protection II :
    - ASUS DIGI+ VRM - 7 Phase digital power design
    ASUS EPU :
    - EPU
    ASUS Exclusive Features :
    - GPU Boost *3
    - AI Suite 3
    - Ai Charger
    - Anti-Surge
    - Low EMI Solution
    - USB 3.0 Boost
    - Disk Unlocker
    - Mobo Connect
    - PC Cleaner
    ASUS Quiet Thermal Solution :
    - Stylish Fanless Design Heat-sink solution & MOS Heatsink
    - ASUS Fan Xpert 2+
    ASUS EZ DIY :
    - ASUS CrashFree BIOS 3
    - ASUS EZ Flash 3
    - ASUS UEFI BIOS EZ Mode
    - Push Notice
    ASUS Q-Design :
    - ASUS Q-Slot
    Media Streamer
  • Operating System Support
    Windows® 10 , 64bit
    Windows® 8.1 , 64bit
    Windows® 7 , 32bit/64bit *3
  • Back I/O Ports
    1 x PS/2 keyboard (purple)
    1 x PS/2 mouse (green)
    1 x DVI-D
    1 x D-Sub
    1 x HDMI
    1 x LAN (RJ45) port(s)
    4 x USB 3.0 (blue) Type-A
    2 x USB 2.0
    3 x Audio jack(s)
  • Internal I/O Ports
    2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s) (19-pin)
    1 x M.2 Socket 3 for M Key, type 2242/2260/2280 devices
    1 x COM port(s) connector(s)
    4 x SATA 6Gb/s connector(s)
    1 x S/PDIF out header(s)
    1 x System panel(s)
    1 x Clear CMOS jumper(s)
  • Accessories
    User's manual
    I/O Shield
    2 x SATA 6Gb/s cable(s)
    1 x M.2 Screw Package
    1 x Supporting DVD
  • BIOS
    128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI3.0, WfM2.0, SM BIOS 3.0 ACPI 5.0, Multi-language BIOS,
    ASUS EZ Flash 3, CrashFree BIOS 3, F11 EZ Tuning Wizard, F6 Qfan Control, F3 My Favorites, Quick Note, Last Modified log, F12 PrintScreen, and ASUS DRAM SPD (Serial Presence Detect) memory information
  • Manageability
  • Support Disc
    Drivers
    ASUS Utilities
    ASUS EZ Update
  • Form Factor
    ATX Form Factor
    12 inch x 8.6 inch ( 30.5 cm x 21.8 cm )
  • Note
    *1: These functions will work depending on the CPU installed.
    *2: Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
    *3: The function supported varies by processor.
    *4:Please refer to ASUS website and download “Windows® 7 installation guide” and “ASUS EZ installer” to install Windows® 7.
H170-PLUS-D3-ASUS-0404.BIN.zip
