Listo, ayudame con el clear ME x favorclearme can fix the delay display, M2 SSDs need to buy a $35 patch
ok just help clearme and I won't help with other problemsListo, ayudame con el clear ME x favor
Hello... Please I need the BIOS for this laptop.
old bios error what ?يوجد مصدر طاقة، كل شيء يعمل ولوحة المفاتيح مضاءة، ولكن لا توجد صورة
The old version works at full power for 20 seconds then restarts again for a minute then everything turns off and only the charging port light stays on....and this is the old versionold bios error what ?
Hello, I have this equipment that arrived at our workshop, which indicates that it takes a long time to give video, and does not recognize the m.2, so with the programming that you send, it gives video correctly, without delay in the video, but with no programming it recognizes the m.2. Can you help me fix that, please, I emphasize that we do not have the original BIOS file, apparently the previous technician did not keep a backup.
mainboard: GA-RX5LXD REV1.2
s/n: SN21380J000621
AORUS 15P
CHK: 2304
MODEL NAME: RX5L
Is the BIOS provided as the original BIOS of that laptop itself?It's still the same, it takes a while to give video and it doesn't recognize m.2, pls help.
I'm stating from the start that we don't have the original BIOS because this computer was serviced elsewhere and no backup was made. Therefore, I've asked for your help repairing your ClearMe BIOS so it recognizes the M.2s. Please, if you'd be so kind. I'm sending you the file that works without a delayed display, but it doesn't recognize the M.2s.Is the BIOS provided as the original BIOS of that laptop itself?
so fix M2 need buy patch 35$I'm stating from the start that we don't have the original BIOS because this computer was serviced elsewhere and no backup was made. Therefore, I've asked for your help repairing your ClearMe BIOS so it recognizes the M.2s. Please, if you'd be so kind. I'm sending you the file that works without a delayed display, but it doesn't recognize the M.2s.
If the patch is purchased, what guarantee is there of functionality?so fix M2 need buy patch 35$
Payment link to buy Patch
Correct the problem of not detecting SSD M2?If the patch is purchased, what guarantee is there of functionality?
yes only problem...¿Corregir el problema de no detectar SSD M2?
ok you can buy patch fix M2yes only problem...
I'm still waiting for you to reply, or refund me the $35 money because you didn't fix the bios, you sent a non-working bios.ok you can buy patch fix M2
