Gigabyte GA-MA790FX-DQ6 (rev. 1.0)
AMD 790FX + SB600 Chipset
BIOS MA79XDQ6.F7g
  • Supports AMD Phenom™ / Athlon™ series processors
  • Dual Channel DDR2 1066* memory support for remarkable system performance
  • Quad PCI-E 2.0 x16 graphics interfaces with ATI CrossFireX™ support for extreme gaming performance
  • Integrated SATA 3Gb/s with RAID function and IEEE 1394a connection
  • Integrated dual LAN with Teaming function to provide twice bandwidth of transmission speed
  • High quality 8-ch ALC889A High Definition audio with DTS Connect support, featuring 106dB Signal to Noise Ratio and Full Rate Lossless Audio with Blu-ray/ HD DVD playback support.
  • Ultra Durable 2 motherboard features High Quality CPU Power design with Ferrite core chokes, Low RDS (on) MOSFET and Solid Capacitors.
  • Durable Capacitors that take advantage of Japanese manufactured SMD (Surface Mount Device) Solid Capacitors for enhanced system durability.
  • Re-engineered Thermal Design featuring All Copper Silent-Pipe and Crazy Cool
  • External SATA2 design makes you enjoying "easy to use, easy to go, and easy to play"
* DDR2 1066 is supported with combination of AM2+ processors and DDR2 1066 memory modules, please refer "Memory Support List" for detail memory support information.
MA79XDQ6.F7g.rar
