BIOS G713QM G533-6050A3250201-MB-A03
G713QM G533-6050A325021-MB-A03
BIOS G713QMAS.320
ASUS ROG G533QS - G733QS REV2.0 - 60NR05E0-MB3000 - 6050A3250201 - 6050A3250203
ASUS ROG STRIX G733QS INVENTEC G533 photo
G713QM.320.bin.zip
G533QS V20 G733QS bdv.pdf
G533QS REV2.0 BoardView.pdf
G533QS REV2.0.pdf
IT5571E.bin.zip
GN20-E5-A1 VBIOS.BIN.zip
If it doesn't work then why do you want me to move S/n?
Okay, let me put it this way: I don't have proper rework equipment, so soldering/desoldering is a tedious and dangerous process. I would not want to try every possible bios file.
I have a dump from Flash, which is 16777216 bytes long and starts with 0x21000
filename: [email protected]
Code:
11:11:37 ✘ andrei_belov:~/.../ELECTRONICS/Repair$ binwalk [email protected]
DECIMAL       HEXADECIMAL     DESCRIPTION
135168        0x21000         UEFI PI Firmware Volume, volume size: 131072, header size: 96, revision: 0, EFI Firmware File System v2, GUID: 8C8CE578-8A3D-4F1C-3599-896185C32DD3
149960        0x249C8         Certificate in DER format (x509 v3), header length: 4, sequence length: 885
150950        0x24DA6         Certificate in DER format (x509 v3), header length: 4, sequence length: 885
151883        0x2514B         Certificate in DER format (x509 v3), header length: 4, sequence length: 1552
153483        0x2578B         Certificate in DER format (x509 v3), header length: 4, sequence length: 1495
155084        0x25DCC         Certificate in DER format (x509 v3), header length: 4, sequence length: 1512
156701        0x2641D         Certificate in DER format (x509 v3), header length: 4, sequence length: 885
266240        0x41000         UEFI PI Firmware Volume, volume size: 131072, header size: 96, revision: 0, EFI Firmware File System v2, GUID: 8C8CE578-8A3D-4F1C-3599-896185C32DD3
281215        0x44A7F         Certificate in DER format (x509 v3), header length: 4, sequence length: 885
282205        0x44E5D         Certificate in DER format (x509 v3), header length: 4, sequence length: 885
283138        0x45202         Certificate in DER format (x509 v3), header length: 4, sequence length: 1552
284738        0x45842         Certificate in DER format (x509 v3), header length: 4, sequence length: 1495
286339        0x45E83         Certificate in DER format (x509 v3), header length: 4, sequence length: 1512
287956        0x464D4         Certificate in DER format (x509 v3), header length: 4, sequence length: 885
790528        0xC1000         UEFI PI Firmware Volume, volume size: 32768, header size: 96, revision: 0, EFI Firmware File System v2, GUID: 8C8CE578-8A3D-4F1C-3599-896185C32DD3
Your file is G713QM.320.bin, which is also 16777216 bytes long. and also starts with 0x21000
Code:
11:10:55 ✔ andrei_belov:~/.../ELECTRONICS/Repair$ binwalk G713QM.320.bin
1273568       0x136EE0        SHA256 hash constants, little endian
1277952       0x138000        Zlib compressed data, best compression
1414656       0x159600        Zlib compressed data, best compression
1503888       0x16F290        Zlib compressed data, best compression
1519472       0x172F70        Zlib compressed data, best compression
1540272       0x1780B0        Zlib compressed data, best compression
1548176       0x179F90        Zlib compressed data, best compression
1561552       0x17D3D0        Zlib compressed data, best compression
1586752       0x183640        Zlib compressed data, best compression
1599824       0x186950        Zlib compressed data, best compression
1639552       0x190480        Zlib compressed data, best compression
1652560       0x193750        Zlib compressed data, best compression
1704176       0x1A00F0        Zlib compressed data, best compression
1729088       0x1A6240        Zlib compressed data, best compression
1776048       0x1B19B0        Zlib compressed data, best compression
1810096       0x1B9EB0        Zlib compressed data, best compression
1829360       0x1BE9F0        Zlib compressed data, best compression
1851024       0x1C3E90        Zlib compressed data, best compression
1871488       0x1C8E80        Zlib compressed data, best compression
1887760       0x1CCE10        Zlib compressed data, best compression
1908480       0x1D1F00        Zlib compressed data, best compression
2597120       0x27A100        Zlib compressed data, best compression
2615808       0x27EA00        Zlib compressed data, best compression
2616832       0x27EE00        Zlib compressed data, best compression
2636032       0x283900        Zlib compressed data, best compression
2957024       0x2D1EE0        SHA256 hash constants, little endian
The files from the website (both G713QMAS.331 and G713QMAS.321) are EZflash binary files, not the binary stream data ready to be flashed with the programmer. It is 16779264 bytes long and has different offsets. (0x21800)
Code:
11:19:12 ✘ andrei_belov:~/.../ELECTRONICS/Repair$ binwalk G713QMAS.331
0             0x0             AMI Aptio extended EFI capsule, header size: 2048, flags: 0x00010000, capsule size: 16779264
137216        0x21800         UEFI PI Firmware Volume, volume size: 131072, header size: 96, revision: 0, EFI Firmware File System v2, GUID: 8C8CE578-8A3D-4F1C-3599-896185C32DD3
792576        0xC1800         UEFI PI Firmware Volume, volume size: 32768, header size: 96, revision: 0, EFI Firmware File System v2, GUID: 8C8CE578-8A3D-4F1C-3599-896185C32DD3
1275616       0x1376E0        SHA256 hash constants, little endian
1280000       0x138800        Zlib compressed data, best compression
1416704       0x159E00        Zlib compressed data, best compression
1505936       0x16FA90        Zlib compressed data, best compression
1521520       0x173770        Zlib compressed data, best compression
1542320       0x1788B0        Zlib compressed data, best compression
1550224       0x17A790        Zlib compressed data, best compression
1563600       0x17DBD0        Zlib compressed data, best compression
1588800       0x183E40        Zlib compressed data, best compression
1601872       0x187150        Zlib compressed data, best compression
1641600       0x190C80        Zlib compressed data, best compression
Therefore, I was wondering if you could possibly take the NVRAM data with S/N and encryption keys from my file [email protected] and patch your file G713QM.320.bin or build a new bin file from the official EZ image ready to be flashed to the Winbond flash chip. I hope this helps. Thank you!
Have you fixed the laptop and got it working again before thinking about the s/n problem because it's very likely that the error is from the AMD chip instead of the BIOS?
G713QM.zip
Hi can you rebuild this dump?
Mainboard: G533-6050A3250201-MB-A03 (A3)
Issue: Rog logo when power on and blank screen.
I try many dump, also extracted from asus support, but gpu is recognized and driver installed, but at the reboot the driver has the error. If i uninstall driver and reinstall into device manager its work until the next reboot.
SPI_EF6018_128Mbit.bin
AMD no have builds
Please try one BIOS new
hola buenas noches, tienen información de conexión del programador ite.
ejemplo: G701VI KB_pins=34 IZQUIERDA ABAJO 08MM FLASH=56 PD0=6 PD1=7 PD2=24 PD3=26 PD4=21 PD5=23 PD6=25 PD7=20 BUSY=28 STB=15 AFD=10 INIT=14 SLIN= 16 KSI4 =13 KSI5=9 IT8171FN-56
necesito para el g533-6050a3250201-mb-a03(a3)
