Lenovo g40-30 nm-a311
g40-30 nm-a311
M-A311 KB_pins=30 (JKB3) PD0=7 PD1=11 PD2=13 PD3=18 PD4=14 PD5=10 PD6=17 PD7=15 BUSY=4 STB=12 AFD=1 INIT=8 SLIN=9 KSI4=5 KSI5=6
g40-30 nm-a311.zip
IT8586 - g40-30 - NM-A311.bin
NM-A311 r02.pdf
Board View-SILKBOT.pdf
Board View-SILKTOP.pdf
i was asking if the EC file you got for the g40-30 works ok on a g50-30 ? because with this EC file i can't run SUSP# commands
i use vertyanov programmer , and until now i didnt had any troubles flashing SIO's , MEC ITE ENE SMSC nuvoton , and the flash works 100% write and sucessful
so if you say the EC dump of the g40-30 is the same as g50-30 , then must have something wrong somewere .
Lenovo G50-30 80G0_a7cn48ww NM-A311
A7CN48WW
BIOS Notification:
Fixed
  1. Follow LNV PCR to fix UEFI vulnerability LEN-2015-049:Configuration Bypass During S3 Resume.
  2. Fix UEFI vulnerability LEN-2015-084:MemoryConfig variable does not been locked correctly.
EC Notification:
Modified
  1. Save storage mode flag to EC ROM in order to fix storage mode lost when shutdown without AC power.
I have same problem. Change PU401 fix problem. Dump is OK
