Yes i did. But i couldnt upload the file. I got it done. But not sure if it is as good as what you could do. only mobo bios i found on your board was for the alienware version rather then the stripped down dell version. 1.6.1 not the 1.6.0 version board haddo you mean extract BIOS from BIOS update exe ?
you don't know zip or rar it? i think you are not technical not sure even you can program the BIOS??wont let it through because its an exe file!!
Wow! Really? I havent used a zip file creator in YEARS. Didnt even think about it. as for bios writing i have the right equipment. This bios setup by dell is freaking rediculous. Changed everything that used to be standard.you don't know zip or rar it? i think you are not technical not sure even you can program the BIOS??
Thank you for the zip idea!Wow! Really? I havent used a zip file creator in YEARS. Didnt even think about it. as for bios writing i have the right equipment. This bios setup by dell is freaking rediculous. Changed everything that used to be standard.
Did this end? Could you extract it? Or does it cost money? If so let me know how much.Thank you for the zip idea!
Thank You very Much.here
