BIOS Dell Precision 7820 Tower
This is not what I need.
I am not looking for a $35 patch fix. I need the complete BIOS file with the correct Service Tag / asset information for the machine, ready to be programmed.
My request was for the full BIOS, not an additional patch.
If you cannot provide the complete BIOS file as requested, refund the amount already paid so I can buy the correct solution elsewhere.
How can you guide me?
Ho bisogno di un dump BIOS completo e funzionante da 32 MB per la scheda madre Dell Precision 7920 060K5C, pronto per il flashing, con regione ME pulita, Service Tag/dati di inventario trasferibili e senza patch aggiuntive richieste o problemi in modalità produzione.
I am not asking for guidance. I am asking for the correct BIOS file.
If you can provide the requested file, please send it. Otherwise, please refund the payment already made so I can purchase the proper solution elsewhere.
It is impossible to have a BIOS exactly as you require, everything must be customized according to reality
A video would not add much because the behavior is always the same. When power is connected, it shows 4 amber and 7 white LEDs on power button. When the rear button of power supply is pressed, the fans start spinning, but there is still no POST or display. If the RAM is removed, the error code changes, so the board is detecting hardware changes. This is why I suspect a BIOS/firmware issue rather than a completely dead motherboard.
The customer also confirmed that the system froze during a BIOS update from Linux
can not problem bios
