Dell DeLL Latitude E6530 LA-7761P
hello admin the bios you post here are not working. I noticed lately that most bios uploaded are not working anymore.
yes admin, the DELL adapter is not recognized anymore. and the battery won't charge either. although it works but has some issue.
before i've reflash it everything works fine.
do you have a bios Dump for this one admin?
Hello.
I have Dell Latitude E7470.
After windows update battery led starts blinking. And not charging. Saying that battery needs service.
Someone help.
Hello.
Someone help.
You need to redefine it earlier ?
The problem is not related to windows
Thanks for answer. But not understand, if there is problem resolving method, or need to buy a new battery. Can I reflash battery eeprom..
thanks
before where update windown batter work change or not ? and you can try one battrey new.
cho em hỏi chút? mấy con máy dell latitude chíp đời 2-3 sau khi chạy bios sao LAN nó cứ bị chấm than là sao?gập nhiều con rồi.
thường thì do clear me, chứ bios bình thường ko thấy bị trừ khi ko phải do bios
Hi,i have one dell E6530 MB:LA-7761P,i tried these dumps from this page,all dumps work,but i have problem,i cant update bios,no error,nothing only restart and go into windows.Bios version is A02,customer want to update to A22 newest version,otherwise customer is very difficult person,call me 10times on day.Have anyone solution,or maybe have anyone dump with version A22,thanks in advance.
If the laptop works normally you do not need to update
