Dell Dell Inspiron 7568 2-in-1 - 14275-1
Dell Inspiron 3153/3158/7353/7359/7568 System BIOS
BIOS Version 01.05.00,A04
Dell Inspiron 13-7353 (Cottonwood 14275-1)
Schematics Inspiron 7568 2-in-1 14275-1 cottonwood_skl_u_a00_0723_1900
boardview
14275-1 BOTTOM.pdf
Dell Inspiron 7353 - Cottonwood MLK - 14275-1 Boardview (.CAD).cad
14275-1 TOP.pdf
Screen Shot 2021-01-22 at 12.04.59.jpgScreen Shot 2020-12-03 at 17.07.36.jpg
У кого-нибудь есть рабочий дамп для DELL 7359 CPU i3-6100U mb 14275-1 TFFRC
this laptop turns on once, if the BIOS screen saver passes, you run diagnostics with nothing to swear, and under Windows you can work calmly through aida64 for hours. but sometimes hangs on the BIOS. But now it hangs all the time at startup, everything that could be disconnected from the mother or changed, did. And here it was discovered when you pull out the Wi-Fi module, it does not freeze, or you turn off the sensor, the download is also calm, another Wi-Fi is installed. Bios flashed 2 flash drives the main mx25l6473e and the second mx25l3273e, I downloaded the dumps from this forum and vinafix, not one did not work on this laptop.
