Ask Dell 7050 Micro D8-MFF-SF bios needed
Question & Answer Forums
I know this bios but maybe someone solution to change SN, model No etc in this bin to this for 7050??
Next problem Lan card not working on this bin
Nothing change. And this is strainge LOM MAC adress 00:00:FF:FF:FF
Please not care adress
I don't understand how you say it doesn't work? Can't install driver? or not detect LAN card?? or can't access the Internet??? please make a problem video i check.
This is adress from BIOS.
When i try boot via NIC even try boot, at once go to support assist not try boot as normal
On this PC is 1 SPI and each reprogramming remove bios battery
Not Understand
This is only a problem with BIOS clear me
Can you tell me why you don't use the BIOS on the top of the post that I sent but use a different BIOS??
This is not change situation. I try few bios for this topic and situation is the same.
Maybe solution to force push update bios for 7050 to this problematic 3050??
Model may be the same. and while I'm fixing it, I'm just looking at the Motherboard code.
