I flashed it even i replaced the bios chip with new one but I am having issue only caps and fin keys lights up after flash can you please check it again or attach a working bios clean for this motherboard model as I mentioned above . Thanks
not change new ICI flashed it even i replaced the bios chip with new one but I am having issue only caps and fin keys lights up after flash can you please check it again or attach a working bios clean for this motherboard model as I mentioned above . Thanks
Can you please add a clean working bios for model I mentioned above thanksnot change new IC
If all bios have the same problem then you need to check the hardware
on top AvailableCan you please add a clean working bios for model I mentioned above thanks
DAH98NMB8B0 REV:B HF
No Display, Pls ClearMe. Thanks!
UnavailableDo we have schematics or boardview for DAH98NMB8B0 REV B?
clssss.zipEnciende pero no hay video, puede repararla? Un saludo y gracias
clssss.zipplease rebild no video rev b hf
clssss.zipPlease fix my bios no dsplay honor laptop DAH98NMB8C0, thank you
How can I roll back the changes made through the GRUB flash drive? I user the setup_var SaSetup 0x146 0x2 command to change the XMP profile setting from the standard one to 1. After that, the laptop stopped turning on. Here is the bios. Honor magicbook x14 i3-10110u (NBR-WAI9)Please fix my bios no dsplay honor laptop DAH98NMB8C0, thank you
I don't know thisHow can I roll back the changes made through the GRUB flash drive? I user the setup_var SaSetup 0x146 0x2 command to change the XMP profile setting from the standard one to 1. After that, the laptop stopped turning on. Here is the bios. Honor magicbook x14 i3-10110u (NBR-WAI9)
I don't know this
Can you please reset this bios to default values? Exactly this one. "clsss" doesn't work with my model correctlyPlease fix my bios no dsplay honor laptop DAH98NMB8C0, thank you
can notCan you please reset this bios to default values? Exactly this one. "clsss" doesn't work with my model correctly
Please repair, block password
