Khác Battery Charger Controller ISL6251, ISL6251A
Discussion in 'Tools' started by post, Apr 15, 2015.
  1. post
    post Well-Known Member
    Dec 12, 2013
    1,497
    147
    DESCRIPTION
    The ISL6251, ISL6251A is a highly integrated battery charger controller for Li-Ion/Li-Ion polymer batteries and NiMH batteries. High Efficiency is achieved by a synchronous buck topology and the use of a MOSFET,
    instead of a diode, for selecting power from the adapter or battery. The low side MOSFET emulates a diode at light loads to improve the light load efficiency and prevent system
    bus boosting. The constant output voltage can be selected for 2, 3 and 4 series Li-Ion cells with 0.5% accuracy over temperature. It can be also programmed between 4.2V+5%/cell and 4.2V-5%/cell to optimize battery capacity. When supplying the load and battery charger simultaneously, the input current limit for the AC adapter is programmable to within 3% accuracy to avoid overloading the AC adapter, and to allow the system to make efficient use of available adapter power for charging. It also has a wide range of programmable charging current. The ISL6251, ISL6251A provides outputs that are used to monitor the current drawn from the AC adapter, and monitor for the presence of an AC adapter. The ISL6251, ISL6251A automatically transitions from regulating current mode to regulating voltage mode.
    Features
    • ±0.5% Charge Voltage Accuracy (-10°C to 100°C)
    • ±3% Accurate Input Current Limit
    • ±5% Accurate Battery Charge Current Limit
    • ±25% Accurate Battery Trickle Charge Current Limit (ISL6251A)
    • Programmable Charge Current Limit, Adapter Current Limit and Charge Voltage
    • Fixed 300kHz PWM Synchronous Buck Controller with Diode Emulation at Light Load
    • Output for Current Drawn from AC Adapter
    • AC Adapter Present Indicator
    • Fast Input Current Limit Response
    • Input Voltage Range 7V to 25V
    • Support 2, 3 and 4 Cells Battery Pack
    • Up to 17.64V Battery-Voltage Set Point
    • Thermal Shutdown
    • Support Pulse Charging
    • Less than 10μA Battery Leakage Current
    • Charge Any Battery Chemistry: Li-Ion, NiCd, NiMH, etc.
    • Pb-Free Plus Anneal Available (RoHS Compliant)
    Applications
    • Notebook, Desknote and Sub-notebook Computers
    • Personal Digital Assistant
    ISL6251.
    NOTES:
    1. Intersil Pb-free plus anneal products employ special Pb-free material sets; molding compounds/die attach materials and 100% matte tin plate termination finish, which are RoHS compliant and compatible with both SnPb and Pb-free soldering operations. Intersil Pb-free products are MSL classified at
    Pb-free peak reflow temperatures that meet or exceed the Pb-free requirements of IPC/JEDEC J STD-020.
    2. Add “-T” for Tape and Reel.
    Controllers with Inductor MAX1992 MAX1993
    #1 post, Apr 15, 2015
    Similar Threads - Battery Charger Controller Forum Date
    Khác Battery Charger with System Power Selector BQ24751 Tools Apr 15, 2015
    Thủ thuật ipad3 backtrack battery charging circuit iOS - iPhone,iPad,iPod Dec 5, 2014
    Phần mềm BatteryBar - Trình quản lý pin cho laptop Windows PC Jun 16, 2014
    Phần mềm Phần mềm kiểm tra pin laptop - BatteryMon 2.1 Full Windows PC Jun 16, 2014
    Bán Sony Vaio VGP-BPS13/S Premium Laptop Battery Replacement Linh kiện laptop May 30, 2014
  3. post
    Dec 12, 2013
    1,497
    147
    ISL6251
Tags:
