B150M-D D3
BIOS B150M-D-D3-ASUS-0209 16MB
ASUS B150M-D RG.pdf
Great-value micro-ATX B150 with 5X Protection II for dependable stability, LED-illuminated audio shielding and flexible DDR3/DDR3L compatibility
ASUS B150M-D RG.pdf
- 5X Protection II – Advanced hardware safeguards for all-round protection
- DDR3/DDR3L memory compatibility
- Epic gaming audio with LED-illuminated shielding
- Media-acclaimed UEFI BIOS with EZ Flash 3
- CPU
Supports Intel® 14 nm CPU
* Refer to www.asus.com for CPU support list - Chipset
Intel® B150 - Memory
2 x DIMM, Max. 32GB, DDR3 1866(O.C.)/1600/1333 MHz Non-ECC, Un-buffered Memory *
* Refer to www.asus.com for the Memory QVL (Qualified Vendors Lists). - Graphic
Multi-VGA output support : DVI-D/RGB ports
Supports Intel® InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™ - Expansion Slots
1 x PCIe 3.0/2.0 x16 (x16 mode, gray)
2 x PCIe 3.0/2.0 x1
1 x PCI - Storage
Intel® B150 chipset :
6 x SATA 6Gb/s port(s), gray - LAN
Realtek® RTL8111H, 1 x Gigabit LAN Controller(s)
ASUS LAN Guard - Audio
Realtek® ALC887 8-Channel High Definition Audio CODEC *1
- Supports : Jack-detection, Front Panel Jack-retasking
Audio Feature :
- LED-illuminated design - Brighten up your build with the gorgeous illuminated audio trace path.
- Premium Japanese-made audio capacitors: Provide warm, natural and immersive sound with exceptional clarity and fidelity - USB Ports
6 x USB 2.0/1.1 port(s) (2 at back panel, black, Type-A, 4 at mid-board)
6 x USB 3.0/2.0 port(s) (4 at back panel, blue, Type-A, 2 at mid-board) - Special Features
ASUS 5X Protection II :
- ASUS DIGI+ VRM - 6 Phase digital power design
ASUS EPU :
- EPU
ASUS Exclusive Features :
- GPU Boost *3
- AI Suite 3
- Ai Charger
- Anti-Surge
- USB 3.0 Boost
- Disk Unlocker
- Mobo Connect
- PC Cleaner
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 3
- ASUS UEFI BIOS EZ Mode
- Push Notice
ASUS Q-Design :
- ASUS Q-Slot
- ASUS Q-DIMM
Media Streamer - Operating System Support
Windows® 10 , 64bit
Windows® 8.1 , 64bit
Windows® 7 , 32bit/64bit *2 - Back I/O Ports
1 x DVI-D
1 x D-Sub
1 x LAN (RJ45) port(s)
4 x USB 3.0 (blue) Type-A
2 x USB 2.0
1 x Parallel port(s)
3 x Audio jack(s) - Internal I/O Ports
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin)
1 x COM port(s) connector(s)
6 x SATA 6Gb/s connector(s)
1 x Chassis Fan connector(s) (1 x 4 -pin)
1 x S/PDIF out header(s)
1 x 4-pin ATX 12V Power connector(s)
1 x System panel(s)
1 x Clear CMOS jumper(s) - Accessories
User's manual
I/O Shield
2 x SATA 6Gb/s cable(s)
1 x Supporting DVD - BIOS
128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI3.0, WfM2.0, SM BIOS 3.0, ACPI 5.0, Multi-language BIOS, ASUS EZ Flash 3, CrashFree BIOS 3, F6 Qfan Control, F3 My Favorites, Quick Note, Last Modified log, F12 PrintScreen, and ASUS DRAM SPD (Serial Presence Detect) memory information - Manageability
WfM 2.0, DMI 3.0, WOL by PME, PXE - Support Disc
Drivers
ASUS Utilities
EZ Update
Anti-virus software (OEM version) - Form Factor
mATX Form Factor
9.6 inch x 7.2 inch ( 24.4 cm x 18.3 cm ) - Note
*1: Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
*2: Please refer to ASUS website and download “Windows® 7 installation guide” and “ASUS EZ installer” to install Windows® 7.
*3: The funcation supported varies by processor
B150M-D-D3-ASUS-0209.BIN.zip
ASUS B150M-D RG.pdf
