Asus B150 PRO GAMING D3
CEO
Dec 13, 2013
91,519
1
6,284
VinaFix
vinafix.com
ASUS B150 PRO GAMING D3
BIOS B150-PRO-GAMING-D3-ASUS-0402 16MB
Value-packed ATX gaming board with loads of gaming-oriented features
  • LGA1151 socket for 6th-gen Intel® Core™ i7 / Core i5 / Core i3, Pentium® and Celeron Processors
  • Dual DDR3 1866 (O.C.) support
  • SupremeFX: Flawless audio that makes you part of the game
  • Sonic Radar ll: Scan and detect your enemies to dominate
  • Intel Gigabit Ethernet, LANGuard and GameFirst III: Top-speed protected networking
  • RAMCache: Speed up your game loads
  • Gamer's Guardian: Highly-durable components and smart DIY features
  • USB 3.1 Type-A/C and M.2: Ultra-speedy transfers for faster gaming
  • CPU
    Supports Intel® 14 nm CPU
  • Chipset
    Intel® B150
  • Memory
    4 x DIMM, Max. 64GB, DDR3 1866(O.C.)/1600/1333 MHz Non-ECC, Un-buffered Memory
  • Graphic
    Multi-VGA output support : HDMI/RGB ports
    - Supports HDMI with max. resolution 4096 x 2160 @ 24 Hz
  • Multi-GPU Support
  • Expansion Slots
    1 x PCIe 3.0/2.0 x16 (x16 mode, gray)
    1 x PCIe 3.0/2.0 x16 (max at x4 mode, black) *1
    2 x PCIe 3.0/2.0 x1
    2 x PCI
  • Storage
    Intel® B150 chipset :
    1 x M.2 Socket 3with M Key design, type 2242/2260/2280/22110 storage devices support (Supports both SATA & PCIE SSD)*2
    6 x SATA 6Gb/s port(s),
  • LAN
    Intel® I219V, 1 x Gigabit LAN Controller(s), GameFirst technology
    Anti-surge LANGuard
  • Audio
    SupremeFX 8-Channel High Definition Audio CODEC
    - Supports : Jack-detection, Multi-streaming, Front Panel MIC Jack-retasking
    - High quality 115 dB SNR stereo playback output
    Audio Feature :
    - SupremeFX Shielding™ Technology
    - Sonic Radar II
  • USB Ports
    ASMedia® USB 3.1 controller :
    1 x USB 3.1 port(s) (Type-A)
    1 x USB 3.1 port(s) (Type-C, Reversible)
    6 x USB 3.0/2.0 port(s) (4 at back panel, blue, 2 at mid-board)
    6 x USB 2.0/1.1 port(s) (6 at mid-board)
  • Special Features
    Gamer's Guardian:
    - ESD Guards on LAN, Audio, KBMS and USB3.0/2.0 ports
    - DRAM Overcurrent Protection
    - Stainless Steel Back I/O
    - Highly Durable Components
    - DIGI+ VRM
    ASUS EPU :
    - EPU
    ASUS Exclusive Features :
    - AI Suite 3
    - Ai Charger+
    - USB 3.1 Boost
    - Disk Unlocker
    ASUS Quiet Thermal Solution :
    - ASUS Fan Xpert 3
    ASUS EZ DIY :
    - ASUS CrashFree BIOS 3
    - ASUS EZ Flash 3
    - Push Notice
    ASUS Q-Design :
    - ASUS Q-Shield
    - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    - ASUS Q-Slot
    - ASUS Q-DIMM
    Media Streamer
    RAMCache
  • Operating System Support
    Windows® 10 , 64bit
    Windows® 8.1 , 64bit
    Windows® 7 , 32bit/64bit
  • Back I/O Ports
    1 x PS/2 keyboard (purple)
    1 x PS/2 mouse (green)
    1 x D-Sub
    1 x HDMI
    1 x LAN (RJ45) port(s)
    1 x USB 3.1 (red)Type-A
    1 x USB 3.1 Type-C
    4 x USB 3.0
    1 x Optical S/PDIF out
    5 x Audio jack(s)
  • Internal I/O Ports
    1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin)
    3 x USB 2.0 connector(s) support(s) additional 6 USB 2.0 port(s)
    1 x M.2 Socket 3 with M Key design, type 2242/2260/2280/22110 storage devices support (Supports both SATA & PCIE SSD)
    1 x COM port(s) connector(s)
    6 x SATA 6Gb/s connector(s)
    1 x CPU OPT Fan connector(s) (1 x 4 -pin)
    3 x Chassis Fan connector(s) (3 x 4 -pin)
    1 x System panel(s)
    1 x Thermal sensor connector(s)
    1 x CPU OV
    1 x Clear CMOS jumper(s)
    1 x ROG extension (ROG_EXT) header(s)
    1 x 14-1 pin TPM connector
  • Accessories
    User's manual
    I/O Shield
    4 x SATA 6Gb/s cable(s)
    1 x M.2 Screw Package
    1 x Supporting DVD
    1 x 12 in 1 Cable Label (s)
  • BIOS
    128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI 3.0, WfM 2.0, SM BIOS 3.0, ACPI 5.0, Multi-language BIOS, ASUS EZ Flash 3,
    CrashFree BIOS 3, F6 Qfan Control, F3 My Favorites, F9 Quick Note, Last Modified Log, F12 PrintScreen function, and ASUS DRAM SPD (Serial Presence Detect) memory information
  • Manageability
  • Support Disc
    Drivers
    ASUS Utilities
    ASUS EZ Update
  • Form Factor
    ATX Form Factor
    12 inch x 9.3 inch ( 30.5 cm x 23.6 cm )
  • Note
    *Due to Intel® chipset limitation, DDR3 1866 MHz and higher memory modules on XMP mode will run at the maximum transfer rate of DDR3 1866 Mhz.
    **To prevent system instability, either install DDR3L DIMMs or DDR3 DIMMs with voltage lower than 1.5V.
    *1:When PCIE x16_2 is occupied by x4 or faster devices, PCIE x1_1 and PCIE x1_2 will be disabled.
    *2:When the M.2 Socket 3 is operating in SATA mode, SATA port 1 will be disabled.
  • B150-PRO-GAMING-D3-ASUS-0402.BIN.zip
