ASUS VivoBook 14 X411UN
BIOS 7th Kaby Lake
BIOS 7th Kaby Lake
X411UN.307.bin
ANY BIOS AND BOARDVIEW ASUS X411UNV SIR?ASUS VivoBook 14 X411UN
BIOS 7th Kaby Lake
send old bios error i help build, current Unavailable BVANY BIOS AND BOARDVIEW ASUS X411UNV SIR?
PLEASE CLEAR ME SIR...send old bios error i help build, current Unavailable BV
https://vinafix.com/threads/asus-x411unv.36530/Hi! I need EC.
X411UNV REV. 2.4
IT8995E
Do you think x411unv has a lower CPU version?8th gen cpu ?
mbr x411unv , the chassi i only can see the shorter model , saying s410u , i can't see the other code usually s410u(X) but don't knoiw since the sticker was removed .
Yes above is X411UN 7th but you ask X411UNV 8thwell on your first post you mention bios for 7th gen cpu .. so since my cpu is a 8th gen , i asked the question above ! whats you didn't understand ?
send old bios i help buildmachine is with the code ilegible , i only can see on the chassi : S410U the other code was removed ...
on the motherboard the code is a X411UNV and it has a 8th GEN CPU .. so i asked if you have bios for that ! got it now ?
try itHello Thien,
Can you repair this file please, no image problem.
still no image, can you repair my file pls?
it is build from bios you send, check hardware when it same problemstill no image, can you repair my file pls?
Help sir, No switch ON no powerASUS VivoBook 14 X411UN
BIOS 7th Kaby Lake
