ASUS TUF Gaming FX505DD/FX505DT/FX505DU TUF705DT
ASUS TUF Gaming FX505DD/DT/DU
AMD
FX505DT, FX505DU
Schematics FX505DU REV2.0.pdf
FX505DD KB_pins=34 LEFT DOWN 08MM PD0=29 PD1=20 PD2=15 PD3=23 PD4=14 PD5=16 PD6=12 PD7=30 BUSY=26 STB=18 AFD=28 INIT=21 SLIN=19 KSI4=22 KSI5=24
FX505DU 2.0 bv 1.pdf
boardview
FX505DD BoardView.pdf
FX505DD REV2.0.pdf
EC_ FX505DU
Asus TUF FX505DD r2.0 boardview.FZ
FX505DU REV20.pdf
FX505DD REV2.0.pdf
EC_ FX505DU.bin.zip
Can it be programmed with the svood from the keyboard?
FX505DD Rev 2.0 AMD CPU with NVidea GPU
NVidea GPU faulty have error code able to change in bios and disable Nvidea run only AMD APU?
Can't turn it off from the bios but I suspect you just need to remove the GPU and then check the results
AMD
FX505DT, FX505DU
boardview
FX505DD REV2.0.pdf
EC_ FX505DU
View attachment 206075View attachment 167813
fx505dd please fix no display just fan spinning restart
1.BIN
