ASUS ROG Strix GL10DH
AMD® B450
AMD® B450
And what software I should use to backup bios file, because i can't use Asus easyflash?Of course
you need have tool like RT809H or SVOD...And what software I should use to backup bios file, because i can't use Asus easyflash?
RT809H, that tool cost more than the computer is worth... Is the password saved on bios/uefi flash, or is there different chip?you need have tool like RT809H or SVOD...
so this is the job of the technician you can't buy a tool just to fix this one PCbios/uefi f
This is te first time when I have problem with bios password... I don't work with corporate machines, but normal users... And first time probably close 100 motherboards, the bios password is set... So I don't see very likely to hit same problem soon again...so this is the job of the technician you can't buy a tool just to fix this one PC
Ok, I'll give try.. Next week I am back to factory after holiday, there I can use Elnec Beeprog 2c programmer, so basically I think that should be able to read the UEFI chip... But the chip is some "custom", because it is W25Q128JVIQ, at PDIP8 package, and seems that datasheet don't even know that chip on PDIP package...try this, it usually works on low generation PCs, but give it a try and see if it works with yours
- When asked for a password, enter an incorrect password, then press Alt+R. A prompt with the system date will appear, e.g. 2019-04-25
USB is not related to BIOSplease rebuild this bios file
the system dettected thats usb curent voltages
so question great ones i have a asus gl10dh but when i try to flash that bin file in the ez flash in the bios it says incorrect file type or something like that
use tool like RT809H Programmingwhat do i do with that ?Sorry little new to this type of flashing but very quick learner. Show me once ill learn it
