ASUS ROG GL753VE
ASUS ROG GL753VE BIOS
Intel® HM175 Express Chipset (7th #Kabylake)
  • Operating System
    Windows 10 Home
  • Chipset
  • Memory
    2 x SO-DIMM socket , up to 32 GB SDRAM
  • Display
    17.3" (16:9) LED backlit FHD (1920x1080) 60Hz Anti-Glare Panel with 72% NTSC with 178˚ wide-viewing angle display
    17.3" (16:9) LED backlit FHD (1920x1080) 60Hz Anti-Glare Panel with 45% NTSC
  • Graphic
    NVIDIA GeForce GTX 1050TI
  • Storage
    Hard Drives:
    1TB 5400RPM SSH
    1TB 7200RPM SSH
    Solid State Drives:
    128GB/256GB SATA3 SSD
    Solid State Drives:
    256GB/512GB PCIE Gen3X4 SSD
  • Optical Drive
    Super-Multi DVD
  • Keyboard
    Illuminated Chiclet Keyboard
  • Card Reader
  • WebCam
    HD Web Camera
  • Networking
    Wi-Fi
    Integrated 802.11b/g/n
    Integrated 802.11 AC
  • Interface
    1 x USB 3.1 TYPE C port(s)
    3 x USB 3.0 port(s)
    1 x USB 2.0 port(s)
    1 x HDMI
  • Battery
    4 Cells 48 Whrs Battery
  • Power Adapter
    Plug Type :ø5.5 (mm)
    Output :
    19 V DC, 6.32 A, 120 W
  • Dimensions
    415 x 273 x 30 mm (WxDxH)
  • Weight
    2.8 kg with Battery
GL753VE.304.bin.zip
ECROM.bin
Hi there ThienBui. How are you?
So, I have the ASUS FX73VE. As I see the FX73VE bios has the same filename: GL753VE.
I think asus use the same bios for this notebook too. Do you know something about it?
I bricked my bios. So, the bin you shared here is the bin for direct write the bios chip?
Thanks for your help, really appreciate.
right same bios. you can use bios above
  • Operating System
    Windows 10 Home
  • Chipset
  • Memory
  • Display
  • Graphic
  • Storage
    Hard Drives:
    1TB 5400RPM SSH
    1TB 7200RPM SSH
    Solid State Drives:
    Solid State Drives:
  • Optical Drive
    Super-Multi DVD
  • Keyboard
  • Card Reader
  • WebCam
    HD Web Camera
  • Networking
    Wi-Fi
  • Interface
    3 x USB 3.0 port(s)
    1 x USB 2.0 port(s)
    1 x HDMI
  • Battery
  • Power Adapter
    Output :
  • Dimensions
  • Weight
    2.8 kg with Battery
Work for me!Thanks!
Thanks, still the same. any idea what can cause the CPU to show on bios always at 105ºc and shutsdown in a few seconds, fan doesnt spin until 1s before shutdown
You have to check out the other ingredients ....
