Asus ASUS M3N78 SE
ASUS M3N78 SE
BIOS M3N78-SE
Ver: 1002
  • CPU
    AMD Socket AM2+ / AM2 Phenom™ FX/Phenom™/Athlon™ /Sempron™ Processors
    AMD Cool 'n' Quiet™ Technology
    AMD Live!™ Ready
    Support CPU up to 125W
    Support 45nm Phenom™ II CPU
  • Chipset
    NVIDIA nForce 720D (MCP78D)/ GeForce 8200(MCP78S)
  • System Bus
    Up to 5200 MT/s ; HyperTransport™ 3.0 interface for AM2+ CPU
    2000 / 1600 MT/s for AM2 CPU
  • Memory
    2 x DIMM, Max. 8 GB, DDR2 1066*/800/667/533 ECC,Non-ECC,Un-buffered Memory
    Dual Channel memory architecture
    *Due to AMD CPU limitation, DDR2 1066 is supported by AM2+ CPU for one DIMM per channel only.
    *Refer to www.asus.com for the memory QVL (Qualified Vendors List)
  • Expansion Slots
    1 x PCIe x16
    2 x PCIe x1
    3 x PCI
  • Storage
    Chipset
    1 xUltraDMA 133/100
    4 xSATA 3 Gb/s ports Support RAID 0,1,0+1,5
  • LAN
    NVIDIA nForce built-in Gigabit MAC with external Realtek8211CL-GR PHY
  • Audio
    ALC662 High Definition Audio 6 -Channel CODEC
    - Supports Jack-detect and Multistreaming teconologies
    - Supports S/PDIF out interface
  • USB
    12 USB 2.0 ports (6 ports at mid-board, 6 ports at back panel)
  • ASUS Unique Features
    ASUS Quiet Thermal Solution
    - ASUS Q-Fan
    ASUS EZ DIY
    - ASUS CrashFree BIOS 3
    - ASUS EZ Flash 2
    - ASUS MyLogo 2
    - ASUS AI NET 2
  • Overclocking Features
    SFS (Stepless Frequency Selection)
    - HT tuning from 200MHz up to 550MHz at 1MHz increment
    - Adjustable CPU Voltage at 0.05V increment
    - Memory tuning from 533MHz up to 1066MHz
    - PCIe frequency tuning from 100MHz up to 150MHz at 1MHz increment
    Overclocking Protection:
    - ASUS C.P.R. (CPU Parameter Recall)
  • Back Panel I/O Ports
    1 x PS/2 Keyboard/Mouse Combo port
    1 x RJ45 port
    1x LPT
    1x COM
    6 x USB 2.0/1.1
    6-Channel Audio I/O
  • Internal I/O Connectors
    3 x USB connector (6 ports)
    1 x Floppy disk drive connector
    4 x SATA connectors
    1 x CPU Fan connector
    1 x Front panel audio connector
    1 x S/PDIF Out connector
    1 x CD audio in connector
    1 x 24-pin ATX Power connector
    1 x 4-pin ATX +12V Power connector
    1 x System Panel connector
  • BIOS
    8 Mb Flash ROM
    AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0, ASUS EZ Flash 2
  • Accessories
    1 x UltraDMA 133/100/66 cable
    1 x SATA cable
    1 x SATA power cable
    1 x I/O Shield
    User's manual
  • Support Disc
    Drivers
    ASUS PC Probe II
    ASUS Update
  • Form Factor
    ATX Form Factor
    12 inch x 8.6 inch ( 30.5 cm x 21.8 cm )
M3N78-SE-1002.ROM.zip
