ASUS J1900I-C
BIOS J1900I-C-SI-0806
- CPU
Intel® Celeron® Quad-Core J1900 SoC onboard Processors
- Memory
2 x SO-DIMM, Max. 8GB, DDR3L 1333 MHz Non-ECC, Un-buffered Memory
* Refer to www.asus.com for the Memory QVL (Qualified Vendors Lists). - Graphic
Integrated Graphics Processor
Multi-VGA output support : HDMI/RGB ports
- Supports HDMI with max. resolution 1920 x 1080 @ 60 Hz
- Supports RGB with max. resolution 2560 x 1600 @ 60 Hz
Supports DirectX 11 - Expansion Slots
1 x PCIe 2.0 x1
1 x mini-PCIe *2 - Storage
Built-in Controller :
2 x SATA 3Gb/s port(s), dark brown
Supports Intel® Smart Connect Technology - LAN
Realtek® RTL8111G, 1 x Gigabit LAN Controller(s) - Audio
Realtek® ALC887-VD 8-Channel High Definition Audio CODEC *1
- Supports : Jack-detection, Front Panel Jack-retasking - USB Ports
1 x USB 3.0 port(s) (1 at back panel, blue)
6 x USB 2.0 port(s) (4 at back panel, , 2 at mid-board) - Special Features
ASUS Exclusive Features :
- AI Suite 3
- Ai Charger
- Anti-Surge
- Network iControl
- USB 3.0 Boost
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
- ASUS MyLogo 2
100% All High-quality Conductive Polymer Capacitors - Operating System Support
Windows® 8.1
Windows® 8
Windows® 7
Please update your BIOS and drivers to the latest version to support Windows 7 - Back I/O Ports
1 x D-Sub
1 x HDMI
1 x LAN (RJ45) port(s)
1 x USB 3.0
4 x USB 2.0
1 x COM port(s)
3 x Audio jack(s) - Internal I/O Ports
1 x USB 2.0 connector(s) support(s) additional 2 USB 2.0 port(s)
1 x TPM header
1 x LPT header
1 x COM port(s) connector(s)
2 x SATA 3Gb/s connector(s)
1 x CPU Fan connector(s)
1 x Chassis Fan connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x System panel(s)
1 x Clear CMOS jumper(s)
1 x Buzzer - Accessories
User's manual
I/O Shield
2 x SATA 3Gb/s cable(s) - BIOS
64 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.7, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2, ASUS CrashFree BIOS 3, My Favorites, Quick Note, Last Modified log, F12 PrintScreen, F3 Shortcut functions and ASUS DRAM SPD (Serial Presence Detect) memory information - Manageability
WfM 2.0, DMI 2.0, WOL by PME, PXE - Support Disc
Drivers
ASUS Utilities
EZ Update
Anti-virus software (OEM version) - Form Factor
Mini ITX Form Factor
6.7 inch x 6.7 inch ( 17 cm x 17 cm ) - Note
*1:Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
*2:This socket does not support USB Bluetooth signals.
(The PCI Express x1 slots conform to PCI Express 2.0 standard)
*3lease update your BIOS and drivers to the latest version to support Windows 7.
J1900I-C-SI-0806.BIN.zip
