That shows that the original BIOS has absolutely impossible to overcome, you can use another BIOS after buying a $ 35 patch to fix제공되는 BIOS는 몇 분 후에 ASUS 로고를 표시하지만 더 이상 진행되지 않습니다. 도와주세요
SN: N1NRCX12T229049
35달러를 냈어요. 새로운 바이오스를 주세요.이는 원래 BIOS가 절대 극복할 수 없음을 보여주며, $35 패치를 구매한 후 다른 BIOS를 사용하여 수정할 수 있습니다.
send i file bios error SSD35달러를 냈어요. 새로운 바이오스를 주세요.
This is a bios file that is not recognized by the ssd and graphicssend i file bios error SSD
SN: N1NRCX12T229049
clssss.zipPLEASE CLEAR ME INTERMITTENT DISPLAY. TY
model ?REPARAR Y LIMPIAR NO DA VIDEO POR PANTALLA SOLO HDMI
Good day please help
ASUS FX506H
DANJJMB1AA0 rev a
please rebuild my Bios
No Display and Fan Continues spinning
bitlocker only formats HDDHello Sir can you remove the bitlocker
the bios that you give me has a bitlocker thank you
builds8233.ziphi, i have situation with my laptop it wont display with original bios . i have installed the bios file you have on your original page it powers on fine but wont see the ssd so i have performed ME Reset then it start recognise the ssd and load windows everything alright but after shutdown it wont display again unless you install the bios again but if i use the file you have that doesnt detect ssd it will power on and off fine as many times requires . can you help me to sort the issue
it doesnt display anything on the screen with this file
