ASUS A441U X441UV REV 2.1
ASUS VivoBook Max X441UV
  • Processor
  • Operating System
    Windows 10 Home
    Windows 10 Pro
  • Chipset
    Integrated Intel® CPU
  • Memory
    , 1 x SO-DIMM socket , up to 16 GB SDRAM(On selected models)
  • Display
    14.0" (16:9) LED backlit HD (1366x768) Glare Panel with 45% NTSC
    14.0" (16:9) LED backlit FHD (1600x900) Glare Panel with 45% NTSC
    Support ASUS Splendid Technology
  • Graphic
    NVIDIA GeForce 920MX , with 1GB VRAM
  • Storage
    Hard Drives:
    500GB 5400RPM SATA HDD
    1TB 5400RPM SATA HDD
    2TB 5400RPM SATA HDD
  • Optical Drive
    Super-Multi DVD
  • Keyboard
    Chicklet keyboard
  • Card Reader
    Multi-format card reader (SD/SDHC)
  • WebCam
    VGA Web Camera
  • Networking
    Wi-Fi
    Integrated 802.11b/g/n
    Integrated 802.11 AC
    Bluetooth
    Built-in Bluetooth V4.0
  • Interface
    1 x COMBO audio jack
    1 x VGA port
    1 x USB 3.0 port(s)
    1 x USB 2.0 port(s)
    1 x HDMI
    1X AC adapter plug
  • Audio
    ASUS SonicMaster Technology
  • Battery
    36 Whrs Battery
  • Power Adapter
    Plug Type :ø4 (mm)
    Output :
    19 V DC, 2.47 A, 45 W
    Input :
  • Dimensions
    348 x 242 x 27.6 ~ mm (WxDxH)
  • Weight
    1.75 kg with Battery
F441U I5-7200U 4G X441UV Rev 2.1
  • Processor
  • Operating System
    Windows 10 Home
    Windows 10 Pro
  • Chipset
  • Memory
  • Display
  • Graphic
  • Storage
    Hard Drives:
  • Optical Drive
    Super-Multi DVD
  • Keyboard
    Chicklet keyboard
  • Card Reader
  • WebCam
    VGA Web Camera
  • Networking
    Wi-Fi
    Bluetooth
  • Interface
    1 x VGA port
    1 x USB 3.0 port(s)
    1 x USB 2.0 port(s)
    1 x HDMI
    1X AC adapter plug
  • Audio
  • Battery
    36 Whrs Battery
  • Power Adapter
    Plug Type :ø4 (mm)
    Output :
    Input :
  • Dimensions
  • Weight
pleas clear me sir
[QUOTE = "ThienBui, publicación: 43441, miembro: 6"] ASUS VivoBook Max X441UV
  • Procesador Procesador
    Intel® Core ™ i7 6500U, Procesador
    Intel® Core ™ i5 6200U, Procesador
    Intel® Core ™ i3 6100U,
  • Sistema operativo
    Windows 10 Home
    Windows 10 Pro
  • Chipset
  • Memoria
    , 1 zócalo SO-DIMM, hasta 16 GB SDRAM (en modelos seleccionados)
  • Pantalla
    14.0 "(16: 9) Retroiluminación LED HD (1366x768) Panel antideslumbrante con 45% NTSC
    14.0" (16: 9) Panel retroiluminado con LED FHD (1600x900) con 45% de
    compatibilidad NTSC Tecnología ASUS Splendid
  • Gráfico
    NVIDIA GeForce 920MX, con 2 GB de VRAM
    NVIDIA GeForce 920MX, con 1 GB de VRAM
  • Discos duros de almacenamiento :
  • Unidad óptica
    Super-Multi DVD
  • Teclado
    Chicklet teclado
  • Lector
    de tarjetas lector de tarjetas multiformato (SD / SDHC)
  • WebCam
    VGA Web Camera
  • Redes
    Wi-Fi
    integrado 802.11b / g / n
    integrado 802.11 AC
    Bluetooth
    incorporado Bluetooth V4.0
  • Interfaz
    1 x conector de audio COMBO
    1 x puerto VGA
    1 x puerto (s) USB 3.0 1 x puerto (es)
    USB 2.0
    1 x USB-C Gen 1 (hasta 5 Gbps)
    1 x RJ45 LAN Jack para LAN insert
    1 x HDMI
    Conector adaptador de CA 1X
  • Audio
  • Batería
    36 Whrs batería
  • Tipo de enchufe del adaptador de corriente : ø4 (mm)
    Salida:
    Entrada:
  • Dimensiones
    348 x 242 x 27,6 mm (An x P)
  • Peso
    1.75 kg con batería
[/CITAR]
hola me ayudas con la bios de ese modelo gracias
please fix this bios,no display,some bios above not working on my board.x441uv 2.1 ci3 6006u
  • Sistema operativo
    Windows 10 Home
    Windows 10 Pro
  • Chipset
  • Memoria
  • Pantalla
  • Gráfico
  • Unidad óptica
    Super-Multi DVD
  • Teclado
    Chicklet teclado
  • Lector
  • WebCam
    VGA Web Camera
  • Redes
    Wi-Fi
    integrado 802.11 AC
    Bluetooth
  • Interfaz
    1 x puerto VGA
    USB 2.0
    1 x HDMI
  • Audio
  • Batería
    36 Whrs batería
    Salida:
    Entrada:
  • Dimensiones
  • Peso
    1.75 kg con batería
[/CITAR]
please repair no display x441uv rev 2.1 ci3 nvidia
