BIOS AFOX B250 BTC-12p
Hello together,
i'm looking for bios of AFOX B250 BTC-12P.
Thanks in advance for your help!
Regards
same as mine, the motherboard and other hardware are ok, but wont turn on, even using the new bios. (the cpu cooller turns on but no video)
Any have boardview/Schematic Afox B250 BTC 12P v1.1?
i have problems fan run a second and than off, but not boot loop
thanks..
The file I sent you is not allowing Windows to install. If I connect an SSD hard drive, it shows an error right at the start. And if I connect an HDD hard drive, it reaches about 50% and then gives an error. So please clear this file completely so that I can install Windows on it.
B250 BTC-12P.BIN
sata need check chipset
