FLORIAN
- 3.00 star(s)
Hi everyone,
I have a problem that I cannot resolve on an Acer Spin 5 (SP513-51-33RB)
When the pc is connected to the current, this one works normally but as soon as one disconnects the current, this one cuts.
I changed the battery to a new one, and I got the same result.
Under Windows, this appears under load but the percentage does not change (blocked at 60%).
I updated the BIOS as well, to no avail.
I have the impression that it is the relay which switches between the 19v power supply and the battery that is causing the problem.
I downloaded the motherboard datasheet but I can't locate it ...
Can you help me please ?
Thank you
Thank you
