hi all please help me about the original bios bin for this model..tnx
W25Q128BV@WSON8_20230312_80308 bea.BIN
A315-58 FH5AT LA-K093P REV 1B TH I5 TH 11
dis ram on giúp em với
can u remove bild ram la- k093p
túnpass please
please disable onboard ram for this bios..... thanks
FH5AT LA-K093P REV.1b por favor desabiliar ram
bbb.zipHi, need bios for this
Acer A315-58-55A6
Board ID; FH5AT LA-K093P Rev 1C
when turn on, blue light only and turn off.
orig back up bios attached.
thanks...
model this not supportStill the same sir,,can you please disable the built-in ram in bios?
Thanks
The model listed in the back case is this Acer A315-58-55A6model this not support
What do you want me to do with this biosThe model listed in the back case is this Acer A315-58-55A6
but the number 5 and 6 is confusing,if the first one didnt work may be this is the correct model
Acer A315-68-66A6
but I am very sure for the board code and bios bin file I have attached..Board ID; FH5AT LA-K093P Rev 1C
Can you please edit the bios for this mode?Acer A315-68-66A6
disable the built in ram sir please?What do you want me to do with this bios
I check above and say model this not supprot disable from biosdisable the built in ram sir please?
I am not sure if this is the correct model Acer A315-58-55A6
because the number 5 and 6 is confusing,if the first one didnt work may be this is the correct model
Acer A315-68-66A6
but I am very sure for the board code and the attached bin file.
no display.
FH5AT LA-K093P
