Apple A1398 820-3787-a
Hello, do you happen to have working efi image for it, everytime I change the ME regions to the clear one, system does not display and fans run on high speed or do you know the way around that ? please let me know.
Thank you
Thank you
How?
You Clear me but not work ?
How?
I downloaded the efi for EMC 2881, flashed it and system was running very slow, so I analyzed and me version was 9.0.5.1367, so I copied that on the bin file but after that system chimes but no display and fans on high speed.
give full code 820-xxxx I try.. and bios old error what ?
board number is 820-3737, it is not giving any error while flashing, system just does not boot as intended, you had uploaded bios with clean ME and someone had same issue with it, so I thought you might know what be the cause of it.
Apple MacBook Pro Retina 15' A1398 2013
J45G DVT KEPLER 820-3787 051-0675
how to read this bios? and what name of the bios if i use rt809h?
where should i put pin spirom wp and spirom hold?
