BIOS 6-71-NP5R0-D01
Hello,
The file you sent me is the same one that was previously sent to another user (builds7222).
This means my own dump (mentett 5962) was not repaired.
The file also does not detect my NVMe, so it doesn’t work on my machine.
Please send a corrected BIOS based on my dump, not a reused file.
Thank you.
Helló,
A fájl, amit küldtél, ugyanaz, mint amit korábban egy másik felhasználónak küldtél (builds7222).
Ez azt jelenti, hogy a saját szeméttelepemet (mentett 5962) nem javították meg .
A fájl nem ismeri fel az NVMe-t , így nem működik a gépemen.
Kérlek, küldj egy javított BIOS-t a memóriaképem alapján , ne egy újrafelhasznált fájlt.
Köszönöm.
Hello,
I am uploading two BIOS dumps:
  1. WORKING.BIN – this BIOS boots perfectly, fixes the Gigabyte logo freeze, detects the NVMe, and the system works correctly under the operating system as well.
  2. MY_BACKUP.BIN – my original dump, containing my real identifiers.
The WORKING.BIN does not contain my identifiers (serial, UUID, MAC, DMI).
I need a corrected BIOS where you merge my original identifiers from MY_BACKUP.BIN into the WORKING.BIN.
For transparency:
I will also share the WORKING.BIN with other users, because it reliably solves the boot freeze issue.
As a premium member, I expect a proper, personalized solution.
Thank you.
Hello,
For transparency:
Thank you.
edit s/n need buy patch 30$
Can you rebuild it please with Gigabyte 2023 G5 KF bios please?
Because with your lastest build, it post and work but GPU won't install code 10 due to your bios.
Thanks
