NP750XED-KB5ES_PW P05CFG BIOS BA83-04593A
TITAN4 nb6099c_pcb_mb_mp1.0¿Código de la placa base?
old file same problem ?LED rojo con cargador y sin batería, LED verde con cargador y batería pero sin encender
no, con archivo antiguo led azul con cargador y sin bateria, no tengo voltaje de memoria, no tengo EN¿El archivo antiguo presenta el mismo problema?
What was the problem before? How do you know it doesn't have a password?? I think the password is saved in EC audio ic no send please
audio ic image pleaseUnavailable
please provide audio ic noNP750XED-KB5ES_PW P05CFG BIOS BA83-04593A
IC audio name ?please provide audio ic no
urgent please
post main bios file and io nameDoes anyone have EC BIOS for Samsung NP750XGJ board TITAN4 NB6099C_PCB_MB_MP1.0?
I have a board with a damaged Super I/O chip, and I can't copy the file.
IO model ITE IT5571E-128post main bios file and io name
Technical download for 128MBITSAMSUNG. Resource type: BIOS / firmware dump. SPI flash capacity: 16 MB. Verify the exact model and board revision before programming or repair work.
421839649e6cec0392911e2d8163b7a87f374667a47417878a08cc184ce29c2cplease can you build yhis please no power
Technical download for 128MBITSAMSUNG. Resource type: BIOS / firmware dump, BIOS Builds. BIOS build and DMI restoration service: device identity data and firmware regions should be checked before programming. SPI flash capacity: 16 MB. The archive contains 1 entries. Verify the exact model and board revision before programming or repair work.
e47478a07cb225dc79ea1e20dc760b5f6901ff903666dcea5c691281433cca97SPI_204318_128Mbitsamsung_Builds_NP750XED.bin
