HUAWEI MateBook D16 HVY-WAP9 NB2715_MB_V7 AMD
I think it will be normal after you connect the SSD to the working machine for the first time
Please fix my BIOS, no video.
MB : nb2715_mb_v9
AMD ?I am looking for a BIOS dump for a HUAWEI MateBook D 16 (2024), model HVY-WAP9 (Motherboard: NB2715 MB V9).
CMIIT ID: 2020AP10553
S/N: 6NXBB21928800753
The original BIOS chip is completely blank/erased, so I do not have a backup.
Could you please provide a working dump, or confirm if a generic BIOS file for this model will work, or if it requires a specific factory-programmed file?
Yes AMDAMD ?
AMD you can Programming any bios otherYes AMD
AMD is difficult to say. Chipsets are also very error-proneI flashed AMD (https://vinafix.com/threads/huawei-matebook-d16-hvy-wap9-nb2715_mb_v7.43784/post-565439) file, but the device doesn't boot. The fans spin, and the Caps Lock and Fn keys light up. The fans cycle on/off a few times, then the device shuts down completely. It won't turn on again unless I unplug and replug the power cable.
Could you confirm if this dump is actually verified and working? If not, do you have a stable/tested file for this motherboard (NB2715 MB V9)?
Thanks.
I understand. Could you please provide a stable, verified BIOS file for the NB2715 MB V9 board? Also, do you have any specific advice to bypass the memory training/chipset error for this AMD model? Any help is appreciated.AMD is difficult to say. Chipsets are also very error-prone
