ASUS Vivobook X556UV
ASUS Vivobook F556U X556UV
CPU 6th
BIOS X556UV Rev 3.1
Boardview Asus X556UV 3.1.fz
ASUS X556UV-X556UJ-X556UA-X556UB-X556UF-X556UQ-X556UQK-X556UR REV3.1.pdf
  • Processor
    Intel® Core™ i7 6500U Processor,
    Intel® Core™ i5 6200U Processor,
    Intel® Core™ i3 6100U Processor,
  • Operating System
    Windows 10 Home
    Windows 10 Pro
  • Memory
    DDR4 2133MHz SDRAM, 1 x SO-DIMM socket for expansion, up to 12 GB SDRAM
  • Display
    15.6" (16:9) LED backlit HD (1366x768) Glare Panel with 45% NTSC
    15.6" (16:9) LED backlit HD (1366x768) Anit-Glaire Panel with 45% NTSC
    15.6" (16:9) LED backlit FHD (1920x1080) Anit-Glaire Panel with 45% NTSC
  • Graphic
    NVIDIA GeForce 920MX , with 2GB VRAM
  • Storage
    Hard Drives:
    500GB/1TB 5400RPM SATA HDD
    2TB 5400RPM SATA HDD
    500GB/750GB/1TB 7200RPM SATA HDD
    Solid State Drives:
    128GB/256GB SATA3 SSD
  • Optical Drive
    Super-Multi DVD
  • Keyboard
    Chicklet keyboard with isolated Num key
  • Card Reader
    Multi-format card reader (SD/SDHC/SDXC)
  • WebCam
    VGA Web Camera
  • Networking
    Wi-Fi
    Integrated 802.11b/g/n
    10/100/1000 Base T
    Bluetooth
    Built-in Bluetooth V4.0 (Optional)
  • Interface
    1 x COMBO audio jack
    1 x VGA port/Mini D-sub 15-pin for external monitor
    1 x USB 3.0 port(s)
    1 x USB 2.0 port(s)
    1 x USB-C Gen 1 (up to 5 Gbps)
    1 x RJ45 LAN Jack for LAN insert
    1 x HDMI
  • Audio
    ASUS SonicMaster Technology
  • Battery
    2 Cells 38 Whrs Polymer Battery
  • Power Adapter
    Plug Type :ø4 (mm)
    Output :
    19 V DC, 3.42 A, 65 W
    Input :
    100 -240 V AC, 50/60 Hz universal
    3/ 2 pin compact power supply system
  • Dimensions
    38.2 x 25.8 x 2.55 cm (WxDxH)
  • Weight
    2.3 kg (with 2 cell battery) with Battery
  • Security
    Kensington lock
    BIOS Booting User Password Protection
    HDD User Password Protection and Security
  • Manufacturer Warranty
    1-year limited International hardware warranty. *different by country
Asus X556UV_3.1.fz
ASUS VM591U X556UV I7 7th.BIN.zip
it8995 ECROM.bin
X556UV 3.1 6th.BIN
CPU 6th
BIOS X556UV Rev 3.1
  • Processor
  • Operating System
    Windows 10 Home
    Windows 10 Pro
  • Memory
  • Display
  • Graphic
  • Storage
    Hard Drives:
    Solid State Drives:
  • Optical Drive
    Super-Multi DVD
  • Keyboard
  • Card Reader
  • WebCam
    VGA Web Camera
  • Networking
    Wi-Fi
    10/100/1000 Base T
    Bluetooth
  • Interface
    1 x USB 3.0 port(s)
    1 x USB 2.0 port(s)
    1 x HDMI
  • Audio
  • Battery
  • Power Adapter
    Plug Type :ø4 (mm)
    Output :
    Input :
  • Dimensions
  • Weight
  • Security
    Kensington lock
build
x556uv rev 3.1.BIN
