Hola, repare esta bios, no hay imagen.
Thanks
Motherboard code BA41-xxx ?Repair, please.
Hi, I need help repairing a laptop BIOS.
I couldn't find my version (titan4) anywhere.
Why must boot from USB??Sir not boot usb fix this one
Model NP750XQA-KB1UK
Seril number6WRC9FFXC02808V
new windowas not instaledWhy must boot from USB??
If it's a USB problem, it's not related to the BIOSnew windowas not instaled
need to test programmingI have a NP750XED-KC1UK that it's working normally (everything opens) but the CPU is stuck in 0.40 GHz, can it be related with a fault BIOS ? Thanks anyway !
CPU stuck 0.40 GHZ can you fix it ? Thanksneed to test programming
HI TRYCPU stuck 0.40 GHZ can you fix it ? Thanks
its bord issuSame issue... :/
Motherboard code ?reparar porfavor placa no enciende
