Ask nm-d031 rev 1.0
i have a problem with this device. this device display with onboard ram but with external ram not display
Hello! Please can you disable onboard RAM? Its Lenovo ideapad 3 14IIL05 SN PF2JC869 . Thank you so much!
202606.BIN
Thank you so much! It seems not work. After flash no picture, before flash there were picture, only in memtest RAM has errors. Can you please try to fix? Thank you!
RAM has been turned off, it displays naturally, you need to check if the external RAM is working
