Inspiron 14 7425 2-in-1 213084-1
BIOS AMD
BIOS AMD
can not check from biosTOUCHPAD AND KEYBOARD
kéo cuống dưới nạp thêm file khác nếu vẫn thế thì bị chip AMD rồiadmin con file bios 213084-1 khac ko. file tren nap vao 2 vang 5 trang
AMD ko có builds nạp file khác xembuilds giúp e với ạ ( svt: 8VZ77S3 ) @ThienBui
AMD need try one bios new and check hardwarelimpiar por favor no video dell p161g
si trabaja con la 7425 pero teclado no trabajaAMD necesita probar una nueva bios y verificar el hardware
se puede hacer algo ?para repararlimpiar por favor no video dell p161g
AMD bios no have checkse puede hacer algo ?para reparar
This one no display.before uplode pls check..waste of time for us..Inspiron 14 7425 2-in-1 213084-1
BIOS AMD
you need check AMD chipsetThis one no display.before uplode pls check..waste of time for us..
i checked different website in that bios display come..pls check your bios before uplode..don't blam alwys amdAMD no have check BIOSi checked different website in that bios display come..pls check your bios before uplode..don't blam alwys amd
COULD YOU UPLOAD WORKING ONE?This one no display.before uplode pls check..waste of time for us..
GOT FROM OTHERS,WORKING NOWCOULD YOU UPLOAD WORKING ONE?
AMD need Programming one BIOS newPlease help, Dell inspiron 14 2 in 1
NO DISPLAY PROBLEM.
Service Tag: DRQHML3
Atman 14n amd uma
213084-1
noncy$la
Thank you!
AMD necesita programar una nueva BIONo tengo la BIOS original
AMD necesita programar una nueva BIOS
No tengo la bios original
can you help meAMD necesita programar una nueva BIOS
