BIOS Dell XPS 13 7390 2-in-1 DDP31 LA-G172P
BIOS, 10th, DDP31 LA-G172P
13.0.0.1082
Schematics boardview
LA-G172P R10-0527.brd
XPS 13 7390 2-in-1 centenario mb 20190529_pvt_bom.pdf
LA-G172P.cad
UPD4.BIN.zip
UH8.BIN
LA-G172P R10-0527.brd.zip
LA-G172P.zip
same problem =(
What else could be the problem? Maybe you still need to flash UPD4?
Let me remind you of the problem again. Stuck on the logo, the fan is spinning and the keyboard backlight is on. I read in another forum that to modify and fix the BIOS you need a service tag number and all possible information about the motherboard.
Motherboard: DDP31 LA-G172P Rev: 1.0 (A00)
Service Tag: D3YPN53
Chip: 25B256DYIG
I'm attaching the original bios again.
la-g172p_orig.bin
same problem =(
Chip: 25B256DYIG
same problem is bios good
I didn't understand your answer.
Can you please make me a BIOS with my native service tag number?
Chip: 25B256DYIG
Builds require the original BIOS and cannot be built with a service tag
hola esta bios tiene errores para entrar al sistema oparativo si enciendo el portatil por el boton de encendido solo enciende bien si enciende cuando habro la pantalla como viene de fabrica cada vez que no aparece el sistema operativo toca colocar la bios de fabrica dura mucho en encender arreglar o limpiar por favor
DDP31 LA-G172P​
GD25Q256D@SOIC8 bios error.BIN
DDP31 LA-G172P​
builds82.zip
