Flex 5-14ITL05 LC56-14T 203013-1 FXCN31WW.bin
Lenovo Flex 5-14ITL05 - LC56-14T 203013-1.pdf
sir this bios not powering on but tried another bios display ok but ssd not detected plz clear me the bios
send bios this I checkssd not detected
this bios is display ok but ssd not detected clear me the bios
so the original BIOS has failed completely and I can't fix it, because without the original BIOS, I can't fix the SSD problemsir this bios is not powering on
sir actually my custumer updating bios is online the system is no display issu sirso the original BIOS has failed completely and I can't fix it, because without the original BIOS, I can't fix the SSD problem
with new lenovo model when programming other BIOS there will be problems with SSD so i tried to build the original BIOS file you sent but it didn't work, i think you keep trying add another BIOS if suitable it will get SSDs.sir actually my custumer updating bios is online the system is no display issu sir
hi, pls rebuilt this, not image, your files not recognize SSD, this is my original BIOS
HELLO SIR PLZ REMOVE BIOS PASSWORD
MB PN. NO. 203013-1
REMOVE PASSWORD
No display issue with my bios..i tried many other bios display is fine but ssd not detected..so can u fix my old biod..
