Lenovo ideapad 320s-15ISK CIUYA/YB/SA/SB/SD LA-E541P REV 1.0
ECROM LA-E541P
320S-14IKB CIUYA YB SA SD LA-E541P Rev 1.0 11.6.bin
Lenovo 520S-14IKBR LA-E541P 11.8.bin
LA-E541P REV 1.0 clear-me 11.7 test ok
Lenovo IdeaPad 320S series - LA-E541P R10-0110A.cad
Schematics
LS-E543P CIUYA_YB Alpine Sensor Board.pdf
LA-E541P DIUYA_YB_SA_SB_SD (KBL-R).pdf
LS-E541P CIUYA_YB Alpine IO Board.pdf
LS-E542P CIUSA_SB_SD Cruze IO Board.pdf
ECROM LA-E541P.bin
lenovo 320s-14ikb type 80x4 penitum gold processor NO GPU
CIUYA/YB/SA/SB/SD LA-E541P Rev 1.0
Power led keeps on but No video just black and cant entering bios mode
plz help I alredy tried another bios in this thread. but not working
original bios.bin
try more bios other and check hardware
I did try almost every bios in this thread multiple times each. result is same. are you possible to check my bios attached before was broken or not?
so BIOS no problem next need to check hardware
Can't repair laptop if you only know bios programming
any way to convert discrete to UMA? the Nvidia GPU is dead (shorted mosfets). I have tried to shift resistor
for the GPU_PRSNT from RC62 to RC61. but still no display
also tried different bios, is there UMA BIOS? or all the same?
current I no have guide for model this
No image in any BIOS. There is no voltage on the PL14 coil. Resistance 9.3 Ohm. I did not detect any damaged elements in the hardware. Tried reprogramming the BIOS and EC. I mean, it's PCH after all
